Question about Olympus Camedia C-725 Digital Camera
Camera Turns off and flashes light soon after turning on then freezes
Yesterday I wanted to take some special pictures only to find that my camera will not operate consistently and correctly. The main symptom is as follows:- Turn on in Auto mode ? lens extends. Try to take picture ? both viewfinders blank, red light flashes several (exactly 11) times and then the camera locks until I press the red (startup) button, then the lens closes. The same happens most of the time even if I try something simple like: - Turn on ?lens extends Flip up flash ? camera locks up, both viewfinders blank and red light flashes ELEVEN times. I have had the following also:- Turn on ? lens extends Take one or two pictures ? ok Suddenly the viewfinder and lcd go blank and the camera locks. I have not noticed the flashing light in these cases. I have also had occassions in the past, even when the camera was quite new, when the camera will hold the shutter open for aaaaaaggggeeeessss resulting is a whiteout picture. I found on this site a link to a recall for this kind of fault but that only seems to apply to Canon cameras. The camera was bought 25/09/2004. Serial Number is 186095297. I have replaced the batteries and also allowed the whole thing to sit without batteries overnight. This has not had any effect. I have also swapped the memory card over. I am not aware of any jolt or mistreatment of this camera. 1.Please advise the best course of action or any further checks which I can do? 2.Is there a diagnostic tool which can be used from my PC via the USB? 3.Also do the number of flashes of the light tell anyone anything - its always 11 flashes before the whole thing locks? I have been told minimum repair cost - regardless of what is done - will be over £100. This seems absurd if it is a simply corrected fault. 4.Does anyone have any comments on why these repairs should have a minimum charge, after all if the garage change the oil in my car I would not expect them to charge the same as a full service!?
  • Jeff777 Nov 21, 2007
    Geck, I've had the exact same problem- turn the Olympus C725 camera on, do anything and it goes dead and the red light blinks several times. The only solution listed below thus far suggests changing from rechargable to normal batteries. I am using regular batteries, so that is not what is wrong with my camera. Any other solutions?
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
Posted on Oct 16, 2007
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
May 07, 2017 | Kodak EASYSHARE M763 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I am having a problem tranferring pictures from my Z1485 IS camera which is brand new. When I connect the transfer cable and then turn on camera to transfer, the camera turns on as indicated by the on...
there are two things,, you are either want to transfer the digital camera pictures from you camera, and other is you want to connect you camera to pc and want to shoot live,
for transfering,, generally with common drivers ,, once you connect to pc, you will get a drive letter in matter of seconds of time in your pc,, go to windows explorer and view you can find them..
Oct 03, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
I cannot take the picture at all
try turning off your flash, if its possible... then if it persist again, maybe you have an hardware problem inside you camera
Jan 14, 2009 | Fuji FinePix A345 Digital Camera
Using flash freezes up camera
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Everything freezes with a red light after I take a picture
Hi
I had simular prob,,
ended up it was my batt
got new 1 on e-bay camera fine now
May 29, 2007 | Vivitar ViviCam 4000 Digital Camera
Olympus Camedia C-725 Digital Camera Logo
196 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
