JVC model AV56WP30 , went out and made several popping noises. Tv turned off will not come back on. Stand by light flashes on and off. Unplugged , no help. Still pops while trying to come on and then turns off but standby light flashes.
  • 2 more comments
  • superblond Nov 05, 2008
    What most likely is the faulty component that is causing this to go to safety mode and turn off? Jvc customer services states this model does not have lamp/bulb but red/green/blue components. Before it went out a few times the picture would pull inwards and get blurry then go back to normal. (I have electrical experience and have fixed this tv before changing convergence chips. and parts..I would like to get an idea of the problem now to repair myself if possible)
    JVC model AV56WP30, rear projection tv. Picture was occasionally pulling in and distorting on the screen. (blurry) then go back to normal. Then popping noise went out and wont turn on. POwer on lite flashes only. Jvc customer service states this model does not have a lamp/bulb, only red/green/blue components. (tubes,projectors????)What could be the bad component causeing this? I have repaired this tv before (convergence chips) and I would like to again if I had an idea of the parts to check?
    Is the main board the same one that convergence IC chips are on??? Where about is the fuse located? are we talking a fuse like in a car? thanks
    Thanks a lot, I will start here.
    Brigadier General:
  • 6,966 Answers
Popping noise would indicate components that gets burned and or heat damaged. Foremost would be capacitors but wold not discount the semicons. It is even possible that the STKs of the convergence that were toasted. Best would be an ocular inspection with particular focus on areas with any burnt smell.
Since you have performed the convergence repair/replacement before, I am assuming that you have a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. You may want to download these repair pages.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
    Master:
  • 505 Answers
The TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
The Digital Processing Board can be cause for the problem.
However all the following parts can be involved.
Parts involved can be
Replacement Ballast
LCD Controller
Time to get the TV repaired. You can go to the following website for detail Parts List.
http://www.shopjimmy.com/TVs/JVC/JVC-TV-Parts.html
Thanks
    Scholar:
  • 155 Answers
The minute electrical components on the main board of your tv are getting short somewhere on the tracks.check it out.and also check the fuse of the tv on the main board may be that fuse has blown and the tv not getting ON.just check that out and replace if its blown. thanks.
  • 19,396 Answers
THE tv KEEPS POPPING BECAUSE IT IS IN PROTECT MODE, THAT IS A SPECIAL SAFETY MODE THAT IS AUTOMATICALLY STARTED WHEN THERE IS A FULTY COMPONENT.
wHEN THIS HAPPENS THE TV MUST USUALLY BE INSPECTED BY A TECHNICIAN
  • Ginko
    Ginko Nov 05, 2008
    Hi there, sorry for my previous reply in capitals, I experienced a problem with the keyboard.
    Effectively AV56WP30 does not have a lamp, but CRT. However, when problem is with CRT, you usually get no raster at all, therefore this does not seem to be the case.
    As I told you before the TV does not turn on and stays in standby because it is gone in
    protect mode, this happens when the TV main chipset detects that there
    is an internal problem, sugh as a wrong voltage, a capacitor that had
    blown, a defective integrated circuit, or any other internal fault.
    If
    the TV does not restart after leaving it unplugged overnight, that
    means that there is an internal fault, and something inside TV must be
    replaced or re-soldered (bad joint).
    Unless you get a determined error message is not easy to understand from here what is wrong with your TV.
    The fact that picture gets distorted let me think that there may be again a problem with convergence ICs. Test again the pico fuses at the base of the convence STKs.
    Try also performing a complete convergence setup from service mode.
    If you get double picture on a rear projection CRT, that means that the convergence problem.
    If the picture is blurry check also the tuner board, or the tuner circuit area on the main board.
    Also inspect the power board and check if any capacitor looks deformed or has burned areas on the board.
    A defective power board can cause any kind of side effects.
    If you do not find anything suspect with such a general inspection, then you will need to get the service manual and follow the troubleshooting diagrams, so to locate and fix the problem.
    You can buy the service manual here:JVC AV56WP30/B Service Manual
    In case you cannot find the fault, calling the manufacturer you can ask the price for a warranty extension.
    A warranty extension will cover any repair for the next year in case the original warranty is expired.
    A warranty extension is often less expensive than a single repair job.
Lt 50a330 jvc
I was watching my tv model LT-50a330 JVC and it made two popping noises and the screen went balck but the green power light stayed on. I unplugged it and could smell something bad like a short. I havnt tried to turn it back on, does this mean I need a new tv, it's not even two yrs old.
Aug 02, 2013 | Hitachi L42A403 42 in. LCD HDTV
How to adjust the convergence on jvc av56wp30 hdtv
Start in the center of the grid and work you way out in circles....do small adjustments....its better to make several passes...Look on the tv repair tips page on www.TvRepairKits.com for more info.
Jan 29, 2013 | Philips Magnavox 9P6034C 60" Rear...
I heard a loud pop then the tv turned off
First check the COF ic's on the buffer boards. Next check the main mosfets in the power supply.
Nov 13, 2011 | Televison & Video
JVC HD56G647 TV was working fine. Made a popping noise and now we have no picture or sound. Both lights on the front are flashing in unison. Help!
The popping noise is not a good sign. You definitely have a shorted horizontal IC and probably a bad flyback transformer. You will find several bad capacitors that contributed to this problem. The cost of repair will be more than your depreciated TV is worth. Sorry..look for a new one. Thanks for asking and show a few hands of support!
Jan 24, 2011 | JVC Televison & Video
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
JVC AV-48wp55 Made a loud noise and went dead instantly.
WELL IF IT WAS A LOUD POP,YOU NEED TO REPLACE THE FLYBACK TRANSFORMER,GET THE MAKE AND MODEL # AND DATE OFF THE BACK OF TV, AND CALL MATS ELECTRONICS #1-800-628-1118
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Jvc th-c50 won't turn on-already changed the fuse even though the old one had very low resistance when tested w/my multimeter.if unplugged for several minutes the stand by light will flash once when...
i was having a simalar problem and was trying to replace the ceramic fuse with a glass one and it wasnt working. i have found the part number for jvc if you want to try and order the ceramic fuse from them and try that. QMFZ059-1R0-E its $8 after shipping.
Jun 11, 2009 | JVC TH-C50 System
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Won't turn on
Problem is caused by Diode Ref.#D620.
Sony Part#871907443.Cost $5.00
May 11, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
Top Televison & Video Experts
