Cameras Logo
Posted on Nov 04, 2008
Card lock When I turned my canon camera Power shot A530 on today it shows card locked. I can view my pictures, but I cannot take a picture. Joyce
amir251700
Level 1:
  • Contributor 50 Answers
  • Posted on Nov 04, 2008
amir251700
Contributor
Level 1:
Answers
50
Questions
Helped
13390
Points
86
There is a little switch on the left side of SD cards; if it's down, your card is locked and you cannot copy anything on it or delete anyfile, also you cannot take any picture by it. so you have to change the switch postion. just this! I hope this helps...
7helpful
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Power shot A530 digital camera
there is no display
or the pictures are black??
Computer won't reconize power shot a530
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
When turned on, my Canon Power Shot A530 has a message that says N imagen, it does not prepare the lens for pictures, just stays with the black screen and the N imagen message.... do you have a solution?
try to change your SD card else There is an external software which you can install in your memory card and then you can insert it in your camera and if it does not work then go to canon service provide
2helpful
KEY LOCKED??!!
my cannon A530 the card said locked
hmmmm.
then try this way.
when you are aiming the object press the DISP or DISPLAY button in the camera.
your LCD must turn ON.
1helpful
3answers
My card is locked, how do i unlock it?
Pull the card out, and make sure that it's not locked. If you're looking at the front of the card it's 1/3 of the way down on the left side. I've got one that has a grey tab and one that is white. They both should be up to unlock it.
12helpful
4answers
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
