Question about Panasonic PT-61G54 61" Rear Projection Television
Picture is jumpy and expands
I have a panasonic pt-61g54c was working fine then all of a sudden picture went dark and started jumping up and down and picture expands like if your watching behind a magnifing glass then go's normal then back. hoping this is not serious and expensive fix. before i call an expert to repair it ...thanks
  • nazmar May 02, 2008
    i have a 52" panasonic tv rear projection and it seems only to do this during action scenes where that are explosions but the picture will expand and them go back to normal, could it be a mirror out of allinement or the circut?
  • yodie213 May 31, 2008
    i have a pt-61g41v my picture jumps too. i need a service manual for this tv. so i know where the circuit is. the service menu has been compromised. when i got the tv it was in service mode. ive turned it off but i need the original settings if at all possible. thanks
    Sergeant:
  • 337 Answers
Right now it should not be expensive to repair but dont use it anymore or it might become worst,sound like loose conections in the horizontal circuit ,seek assistance it should not be expensive to correct.
Posted on Oct 02, 2006
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
Panasonic blue convergence problem
need to replace both stk392-110 , one is for vertical and the other for horizontal , if one is bad the otrere one would go bad anytime
May 07, 2009 | Televison & Video
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red screen with double picture
i have a Panasonic Projection HDTV pt-47wx49e and the picture comes in jumpy and very discolored is there any thing i can do to fix it.
Mar 28, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53TW53G
Mikey,
There are any number of possible failures that can cause the symptoms you're describing. For example, C509 a .47uf/250v mylar cap has been known to fail in those units causing the wavy lines. On the other hand convergence amp failures can do the same thing. That unit uses two STK392-110 Sanyo amps at pos# Ic7001,Ic7002 Panasonic p/n# C5aa00000203 and more in that circuit needs to be tested and signal traced to isolate all of the problem if the amps are the culprit. In short, I don't think this is one you want to tackle with less than a 20 mhz scope and some serious background in electronics.
Bill
Dec 11, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Picture suddenly went dark
Hi, Apparently you have a possible component failure with your Panasonic PVQ-2510. This would involve the circuitry at the back/neck of the picture tube. Diagnosis would require familiarity with discreet components, use of a VOM, soldering and general component knowledge. In as much as it is possible that your red drive transistor (or an IC) would require replacement or resoldering, your best bet is to seek the services of a qualified professional. Should you venture to do a do-it-yourself, pls post back. Good luck and kind regards.
Oct 02, 2007 | Panasonic PVQ-2510 25 in. Combo
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Sep 14, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-61G54 61" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
