The left fan makes a lot of sound.
Get a can of compressed air and give a good blast to open ports and cooling fans, this may resolve the issue, if not the fan will need to be replaced. I do recommend the computer be taken apart down the road for good cleaning.
Thanks, I think my fan is just broken so I am going to get it replaced. You mentioned that I should clean my computer. Are there specific areas I should focus on?
When you take it apart remove the fans and heatsink and blow out any dirt present, remove old thermal grease if dried out, use rubbing alcohol to remove. Then apply fresh thermal grease to the processor and heatsink small amount only and spread evenly and assemble
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
