How do i hook two dj amps together
How do i hook two pyle pro pzr together?what cables do i need?
  • 1,512 Answers
Hi
If you have speakers that are rated to handle at least 600wrms, then I would run each amp in bridge mode, with left going to one and right to the other. If you have 2 pairs of speakers, then you may have to invest in some Y splitter cables or adapters to send right and left to each amp running in stereo.
check out the different configurations you can do in the instruction manual here
The details of exactly the connectors/cables you will need to do this are also all in the manual. the only special thing you need if you go the 2 pair of speakers in a Y adapter. Most electronic hobby shops sell these. Happy to answer any questions you have about this.
Cheers
regards
robotek
Posted on Nov 04, 2008
Turntable won't turn pyle pro
Are you sure that the motor is actually spinning and if it is there is a belt that drives the capistan drive
Apr 19, 2014 | Pyle Pro - PTCDS2UI - Classical Turntable...
PYLE PTA 3000 cut off and will not come on
Will it no longer come on anymore, or does it take multiple tries before it comes on? If it has stopped coming on all together, you may have blown a component on the unit.
Oct 20, 2013 | Pyle Pro Ppa300 3000 Watt 2 Channel Dj...
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Pyle Pro PZR 3000 Watt
I think you will find that something has failed and is causing a short circuit, that's the reason the fuses are blowing and not because you are fitting the wrong type.
I should look at the main devices (anything on a heat sink) first. If they are transistors, you can test them with a Ohm meter. If it gives a reading as if the transitors was acting like a piece of wire, it's gone.
Sometimes you might see evidence of burning or even a hole in something.
Sep 09, 2009 | Audio Players & Recorders
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Reset button
Without owning one , I checked the manual and, sure enough, there's no circuit breaker shown. I mailed tech support. Meantime check where the AC comes in and the fuse holder ( unplugged) and see if you can find anything.
Jan 03, 2008 | Pyle PZR-1000 Amplifier
466 people viewed this question
 Grubhead
Grubhead
