Question about Tools & Hardware - Others
Router repair I'm trying to get a Rockwell 1002 router apart for repair. I cant get the collet nut off the motor shaft. Any suggestions?
  • 359 Answers
Get one of the tiny little torches you use to thaw locks ( not muck bigger than a propane lighter put a small amount of heat all around the Collete and re-try you'd be surprised
Posted on Dec 03, 2008
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: . The direct link to the manual is . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
Change a router bit in a black and decker router
Should be a collet nut on shaft. grasp shaft with vicegrips and loosen collet nut with wrench.
Jan 09, 2016 | Black and Decker USA Vintage Black &...
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
With the router bit facing up, which way to loosen the holding nut? It is rusted and I don't want to force it the wrong way.
All routers use a right-handed thread. With the bit facing up, you will turn the nut counter-clockwise. And here's a little tip. If this router requires you to use two wrenches (one to hold the shaft still and the other to turn the collet nut) then put the wrench on the shaft at the 6 o'clock postion and put the wrench on the collet nut at the 7 o'clock postion - then squeeze the two wrenches together. This works incredibly better than having the two wrenches at some distance apart. Please vote if you found this helpful. Good luck, Al K
Mar 02, 2011 | Ryobi ROUTER KIT P163K
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Oct 19, 2010 | Hitachi M12V2 3Router
How do you change the collets on the Hitachi m12v2?
Matt, Remove the collet nut completely. The collet should come right out of the end of the motor shaft. Put the other collet in it's place and replace the same nut. I assume you are switching between 1/2 inch and 1/4 inch tools.
Aug 23, 2010 | Hitachi M12V2 3Router
Aguired a black and decker model 7600 router tool. Did not come with instruction manual. I cannot determine how to change the bits.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
Jun 15, 2010 | Black & Decker Tools & Hardware - Others
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
How do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 29, 2008 | Makita 3612C Router
Tools & Hardware - Others Logo
413 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
