Question about Toshiba 50HPX95 50 in. Plasma HDTV
50" toshiba plasma
I get a cricket sound from the right bottom side of my tv even when the tv is muted
  • 42 Answers
The only thing I can think of that moves to make noise is the cooling fan is squeaking for some reason if you are able to remove the back of your TV look to see if your fans are clogged with dust and clean them if they are
Posted on Nov 21, 2008
Lost sound on tv suddenly
Just check whether the mute button on remote is jammed. Then if that is ok, check whether you can listen to the sound on a Head Phone connected to the TV. Even if it works, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung PN50A550 50 in. Plasma TV
Multiple vertical white lines
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
If you need any more assistance feel free to contact me through fixya.
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50 inch panasonic 720 plasma tv and while watching it last night a large black box with white writing came on in the top right corner of the screen with mute in it and the sound went off. I...
Unplug the TV. Replug in the TV. If it's still there, you probably have a bad panel. Try changing inputs. These panels are non-repairable.
Jun 16, 2011 | Televison & Video
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Buzzing/humming sound from rear of TV unaffected by volume settin
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Sound problem
Maybe you do have a cricket behind your TV? Gee......i don't know how to help you,cause i don't know the rest of your components and how they are connected?
Oct 12, 2008 | Denon AVR-2807 Receiver
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Fixing the Zenith 50" plasma
The problem is probably a shorted Z Sustain board located on the right side of the TV when viewed from the rear. The board sells for about $220.00. The pop sound comes from the speakers because the audio circuit is not properly muted before power down.
Jun 09, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Toshiba 50HPX95 50 in. Plasma HDTV Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
