Question about Ovens
Sunbeam electric fireplace
Everything works but the blower and heating element i bypassed the switch with a jumper wire and still nothing is this a trannsformer problem?
  • Anonymous Jan 07, 2009
    Sunbeam 'Electric Fire Place' model FL18-R. Fake Flame unit working good. Blower motor is working. There is 110 VAC at the leads going to the heating elements. Thermal Fuse testing good.
    Help!
    dlewis1@ameritech.net
5 Suggested Answers
SOURCE: sunbeam electric fireplace
Where Can I get parts for the sunbeam fireplace.......heater and fan unit???
Posted on Sep 23, 2008
Most likely sounds like the thermal fuse has gone out. if you take off the top of the fireplace you will find a little metal tube in front of the blower. This is the thermal fuse if it has gone out only your fan will blow and the heating element will not put out heat. You can pick one of the fuses up at radio shack for 3 dollars. the only problem is how to go about repacing it since it was crimped in and you can't use a soldering iron because it will trip it. If I come up with a way to change it I will let you know so far I can't.
Posted on Apr 11, 2009
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: my sunbeam fireplace heater shuts
my mircowave oven unlock,how to unlock it.
Posted on Mar 05, 2011
My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
A thorough inspection must be made of the elements and wiring.
Help Me Find My Model Number
Dec 12, 2016 | DeLonghi Ovens
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
My Candy FPP6071X oven won't heat up. The grill and everything else is working fine. Any suggestions?
As you can see on the electrical diagram grill heating element (RG) work alone or in seria with inner lower heating element (RI) and based on the your statement, I conclude that does not work lower heater (RD). So, you should check resistance of lower heater (RD), contacts of change over switch (P7-7 and P6-6) and wiring. By the way, both heater (RI + RD) is integrated into a single heating element.
Dado
Feb 22, 2015 | Candy Ovens
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Heating element won't heat. Checked breaker, turned off then on, and can't see any fuses in control hatch everything else is working. reset clock, canceled all timers. What now!
It gets tricky from there...
I would check for power at the element....if there is power and the element is not getting hot then you have a bad element.... 220 volts across the two wires to the element or more is considered proper power...
If there is no power there.... then you need to flow the wires back till you get power and that is where your problem is....
This is the best way to troubleshoot your oven...but a good quality electrical meter is needed.... and you need to be very careful when working with electric as it can kill you!!!
heatman101
Nov 06, 2010 | Dacor ECS127 Epicure Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dec 11, 2007 | Ovens
Ovens Logo
965 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
