Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Fi=5120c conflict with another scanner
Is there a way to have both the Fujitsu Scan Partner fi-5120C, document scanner, and Canon canoscan 8600f photo scanner, installed on the same machine without having a conflict. I had the fi-5120C installed, working perfectly, then installed the Canoscan 8600f and it conflicts with the fi-5120C. When I try to scan a document on the fi-5120C, the Canoscan expects to scan it.
    Problem Solver:
  • 15 Answers
Check in the order as i had written.
1. Is both the scanners are connected in usb, then this problem will arise. Connect fujistu in scsi and check it. And connect only the cannon and check. because there is a chance of usb port or usb cable problem.
2. Then it depends up on the driver you are selecting. whether you may be selecting fujitsu and giving scan .
3. Check is the driver for cannon is properly installed and also have a check in the device manager is there is any question mark is showing in the driver for particular scanner.
4. If you are using any certain application like scandall application you can select the scanner whichyou want it to scan by selecting the SELECT SCANNER.
5. Is your driver is a new version. If new version is available then update the driver and check it out.
If you have any other problem you can contact me .Regd. the fujistu i can help you.
My mail id is : ramanathanr@integramicro.com.
Posted on Nov 11, 2008
  • 928 Answers
Kindly reply back immediately once you get my email.
Posted on Nov 04, 2008
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
Hello, I work for a doctor's office and we scan a lot of documents. Lately we are getting a code ds42003 on a fijitsu scanner, what should i do this code is on the fi-4010cu, we also have a fi-5120c...
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
Nov 28, 2017 | Fujitsu fi-5120C
Like regarding profile creation
I already sent the email a while ago. Please check your junk mail
Nov 04, 2008 | Fujitsu fi-5120C
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Fujitsu 5120C Scanner
http://193.128.183.41/home/v3__product.asp?pid=462&inf=doc&wg=75
Dec 12, 2007 | Fujitsu fi-5120C
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
FI-5120c
Invalid orientation/long scan combination. Check the KScan ScanDirectionCap and ScanContinuousCap properties and set ScanDirection and ScanContinuous accordingly is for error 20080 and for 20090 means Peripheral stopped by user. Stop button was pressed.
Jul 31, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
349 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
