Question about Creative Labs ZEN SLEEK MP3 Player
Inst. cd I just reinstalled my OS and had to reinstall several pieces of software including my player and I discovered that the cd is scratched and stuff and won't work:( I can add songs and pics to my player but it would bee a whole lot easier with the player manager.
    President:
  • 4,402 Answers
You can take it to any re-sale game/video store and some video rental stores and they can fix the scratches for about 5 bucks.
Posted on Feb 22, 2008
? on Macintosh screen after wiped, how to reinstall OS?
install system disc and power down with disc inside. power up with holding down c key.
Jan 03, 2014 | Apple iMac OS 9.1
Dear Sir, Madam My computer crashed and now all
If you have the software to your ( OS ) Operating System re-install and boot from the CD. There should be an operation for repair or reinstall for now choose repair. Allow the computer to boot and then reinstall all your software including downloading the latest drivers for your NEC be sure the drivers are compatible with the ( OS ).
Feb 28, 2011 | NEC ND-3550A DVD RW Dual Layer Burner
I recently purchased a new Mac Pro computer with OS 10.6.3. I installed the 4600 CD then discovered that It does not work with this OS. I downloaded the upgrade from Lexmark and installed it. Now I get...
I suggest you uninstall the Lexmark software first. To reinstall, click on this link to download: http://bit.ly/9xRlVn. Execute the file and follow the instructions on the software. Thanks.
Aug 05, 2010 | Lexmark X4650 InkJet Printer
My dell optiplex gx520 sounds like it continues to startup for 20+ minutes. Windows load but I cannot do anything.
possibly your windows has become corrupted..try reinstalling it..if your dell came with pre-installed software,then you could use the OS reinstallation cd..note that you may loose all your data since reinstallation will include formating and deleting all your previous data
Jun 04, 2010 | Dell OptiPlex GX520 PC Desktop
Os reinstallation /repair
Yes try to do so, select boot from CD using OS CD, follow the instruction, after searching previous Operating System type "r" to repair the OS
Apr 11, 2010 | Microsoft Windows XP Professional
When i try to reinstall the installation disk my
It seems if you have installed that CD before, if yes, all you need is just check weather you removed it properly.
Also check that the CD your are installing is scratch -free. doesn't contains any viruses.
if still this problem occurs then just open the CD-ROM after your PC has started running the disk.
Open that folder and manually install the software you require.
Oct 18, 2009 | Philips GoGear HDD1830 MP3 Player
AC'97 Audio Codecs Blue screen of death on install please help me fix this problem thanks dell dimension 2350
This usually means your HD has a virus. It could be a boot virus. The best way to get rid of it is to completely reinstall your OS. When you turn on your computer put in your OS software or recovery software (if software recovery does not work you will have to put on new version of OS from another disk). After you put the disk in, restart your computer and hit Enter when the screen prompts to Boot from CD...
If this does not work, you can purchase a anti-boot virus software from your local comp store, otherwise you may need a new HD. But try reinstalling the OS from scratch, that is the best way.
Oct 03, 2009 | Dell Dimension 2350 PC Desktop
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Zen sleek photo installation cd broke
go to this web adress and download the software from there unzip and your mp3 should work again http://www.mpioamerica.com/support/software/IMP-90%20Installation%20CD.zip let me know if you need any more help with this matter. Many thanks
Sep 15, 2006 | i-Bulldog IMP-90 MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
48 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
