Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD-P50A5-K 50 inI
I need factory settings for this TV
  • mulvaney Nov 07, 2008
    Thank You for trying but my tv does not have a home menu or a disply button. When I put it in standby there is no home menu only menu on remote. It did not work.
  • mulvaney Nov 08, 2008
    TV works fine when I go into the factory settings which is a small hole in the front of the tv push it with a pin and factory settings come up which are zeroed out. when I push keys on remote keypad number one is skew number 2 is bow and if i push number 2 twice it goes into 4th bow there are other buttons one through zero have different offerings like sub pin,sub key and so forth.
    Genius:
  • 1,550 Answers
1 With tv off/in standby....press home menu.
2 Within 3 sec turn tv on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow left or right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power tv off and unplug from the wall for 5 or more min.
Posted on Nov 04, 2008
    Scholar:
  • 124 Answers
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
  • Mike H. Nov 07, 2008
    I am still not clear whats going on with your television.
    Do you have a pictures?
    Did you had picture before and now no picture?
    Or picture without the menu?
    Or cant view your DVD player on the televsion?
    Or cant view your antenna signal on the television?
    Please provide some details of whats going on with the television and what you are tying to do.
    Thanks,
    Mike
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer projection tv SD-p5oa3
only codes for pioneer tv are 0166 0679 otherwise
Mar 11, 2008 | Pioneer SD-P50A3-K TV
Need new remote not sure were to buy one please can u help me nsw Pioneer Widescreen Rear Projection TV SD-T50W1
You can buy a universal remote in Radio Shack, Best Buys, Circuit City, etc. or any department or appliance store. A factory replacement remote is available from the manufacturer, Pioneer.
Mar 09, 2008 | Televison & Video
Pioneer SD-T5022 Broke Screen
Call your local TV repair shops ask if they have any used screens ,From sets junked out. most shops sell them 100.00 or little more.order new from factory 500.00 Good Luck with your hunt .ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Dec 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
118 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
