Atrix CSCI-A9001-C4 giving false alarms and clock faulty
  • jonkape Nov 07, 2008
    I was asked to give more information:
    When I start my PC and shuts down beeps normally but sometimes at startup keeps beeping as if some of the components were overheating.
    I have to press the reset button for the display on the front of the case to stop the beeping. After that I can use my PC with no problems. Also, I adjust the real time on the case display clock but after switching the PC off and on it looses the correct time. Thanking you for your help, jonkape.
  • jonkape Nov 13, 2008
    Hi there!
    I did what you recommended but the beeping problem still the same.
    The temperature readings were always OK.
    Thank you, jonkape.
    Brigadier General:
  • 6,966 Answers
Initially, would suggest to check the Lithium backup battery and to reset the CMOS to default. Thereafter, clean and re-seat an add-on cards including the memory modules.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 07, 2008
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Master:
  • 763 Answers
As for beeping sounds remove the memory (ram) from your motherboard, clean it with cloth and insert it correctly. you can switch the time from the CMOS and also from windows xp itself.
thank you for using fixya
CHARCOIS
  • 1,879 Answers
You mean the front panel for TEMP monitoring is giving you wrong readings ?
Disconnect the terminals and do some cleaning then re-connect.
  • 6,487 Answers
Can you please explain your problem further, where do you exactly receive that alarm?
Why does my soleil sun alarm clock keep shutting off
It could be adaptor lead or it could be a faulty socket where it plugs in (most likely, especially if it's been tripped over).
Without further examination with a multimeter it's hard to say.
Jul 20, 2016 | Soleil Sun Alarm Sun Alarm
How do I completely turn off the alarm on one of my alarm clocks?
Turn the alarm selector switch to off. If it still happens you have a faulty clock radio
Oct 04, 2014 | Emerson CK5052 Dual Alarm AM/FM Clock...
Ademco motion detector false alarms
Aside from any sensitivity adjustments, after all a false alarm caused by falling objects, pets or juicy bugs is not a false alarm..it's an environmental mismatch of sensor to the area, some motion detector false alarms are caused by circuit faults, possibly during the install, where the wire terminals were turned too hard and twisted slightly and are not as solid as the manufacturer intended. This twisted terminal mount could cause false alarms when either the power circuit or the sensor circuit loses continuity. Intermittent power (caused by weak/loose/nicked/damaged wiring, a weak terminal on the board or power supply problems could cause annoying faults that are hard to trace. Diligence and a good eye to spot these problems and correct them will help you determine the cause of false alarms.
In the case of wireless devices, troubleshooting is usually limited to spotless battery contacts, good batteries and proper placement.
Aug 23, 2011 | Ademco 998 Pir 50x50 Motion Detector W/...
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
How do Imove icons from screen to another?
Drag and drop then select between Copy and Move.
Jul 09, 2011 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
How to zoom in on pics you are taken?
if you have saved them to your computer in my pictures right click on the photo select open/preview there should be a zoom tab this may vary depending on your operating system in xp you will see a magnifief with a plus+ and minus - in the lower tab of the photos
hope this helps
Apr 02, 2011 | Atrix (CSCI-C8023-C49)
Are there any reported problems with the Firez 21007624 carbon monoxide detector false alarms?
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Mar 22, 2011 | Kidde Firex 21007624 Ac Carbon Monoxide...
Reset clock
Hi there.
I believe that your clock is automatic. It jumps to the signal from the atomic clock somewhere in your area, every hour.
Could be false signal from somewhere.
Iceman.
Nov 10, 2009 | SkyScan 86709 Atomic Wall Clock
Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Dec 20, 2008 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
My alarm keeps going off
Most alarms would kick off only when triggered or when faulty.
triggered - could refer to even false triggering, that is even if no intrusion, the sensors senses something and falsely triggers the alarm. This is the most common cause.
Almost all alarms make use of the door switch (the same door switch that triggers the dome light). Since these switches are more prone to being wet, dirtied or accumulate dust and grime, they are more prone to be the culprits. In most instances, it is a matter of remove, clean and reinstall. In some cases, it could be the wire 9to these switches) that were crinked by the door, panel or any metal part thus creating a short to the ground;
Another possibility is the alarm itself. Most alarms have a logic circuitry with external sensors to provide state/condition of its sensors. It is a simple low/high condition. Dust, weather condition (dampness, cold) could affect the sensitivity, electrical characteristic and therefore be falsely triggered. For this, it would require familiarity with electronic circuitry and components, use of a DVM and perhaps even a soldering iron. Should you be uncomfortable performing a DIY, then perhaps your best bet would be to seek the services of a qualified electronics professional.
Aug 04, 2008 | Nissan Armada Cars & Trucks
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
