Question about Sony STR-DE845 Receiver
  • freddan Nov 04, 2008
    1435432-11 part number
I don't know where you could get one for cheap but you can get one here.
Posted on Mar 05, 2009
My Adcom GCA 510 have a busted transformer. I am still waiting for the Adcom Tech guy to reply regarding the B+ Rails I need to replace the transformer. Maybe you know the the exact B+ rails for the
Basing on 50 wpc could be about 28Vac ( about 48Vdc ) @ 6A min
But check voltage rating of capacitor , if it is 71V then 34V ac is possible
only for the main amp
Note: 34Vac is for 150w may not be applicable to the unit , unless
your modding the circuit.
Oct 02, 2012 | Adcom Audio Players & Recorders
I have a Malibu 300 watt ML300rtw transformer for outside lighting. The timer stopped moving and when I took it apart the small plastic gear was worn down and it was not turning the timer. Is there...
I don't know any site selling power pack gears.
Maybe ebay has gears or sells used power pack.
Easiest thing might be buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Intermatic does not sell the timer module separately, or the gears.
Aug 13, 2011 | Intermatic Malibu 300W Power Pack...
Problem with the catalyst dont pass test what can i do o how i can found a universal catalyst
Heres the problem, these converters are not cheap but if do some research you will see that most aftermarket converter dont last long, maybe a year or two, the next thing is a bad o2 sensor can cause a false converter eff code, have some one test the o2 sensors, a matter of fact if you have close to or over 100,000 miles it would be wise to replace them, theres three or four oxygen sensor or also called air fuel sensors for the front ones, a weak or slow o2 sensor will cause the new converter to go bad. i know its not cheap but something to keep in mind. it would be bad to have a costly converter to fail, anyway what im saying is make sure to get a good converter, we at ours shop learned the hard way, install good aftermarket converter and half of them came back with check engine lights, then we replace them and 6 to 10 months later there back again, this time we went to dealer but we had to pay for that converter which was alomost double the price and were stuck with the aftermarket cats there warranty was out and they wouldnt refund just replace the one that were under warranty and that didnt help as we knew the converter werent strong enough, do your home work on this, must get a nissan or good aftermarket, if you go aftermarket call and ask them about problems with nissan aftermarket converters and what there warranty. we had a few that a company was trying to tell us the car wasnt running good and thats why the converter didnt last, funny thing the nissan only had 40,000 miles and ran like a top and the owner was 76 years old but they tryed not to cover it, good day.
Apr 02, 2011 | 1998 Nissan Maxima
Power Port Damaged
YES it's simple and CHEAP... But you will not be able to do it yourself, unless your power jack is like most IBMs where it's all screw in or unless you are very good at soldering... If it's the kind that needs to be soldered, you will need to take it to an electronic tech guy who can SOLDER it for you...
But first, check and ORDER the correct POWER JACK for your Toshiba laptop from EBAY, it's cheap, maybe under $10 bucks... Then pay the tech to solder it for you, maybe another $20 buck... It's that simple...
Here is the link to your POWER JACK and YES it needs to be SOLDERED on... Good Luck...
Sep 26, 2009 | Toshiba A75-S125 Satellite Notebook
My factory radio went out in my i had a new one put it in. After the guy installed the radio we noticed that my park lights and dash lights werent working. We checked the fuses and they were all...
I really hope that this guy bought a wiring kit to put in the aftermarket radio, because this could be simple. Your stock radio runs the dash and parking lights threw it's display and that needs to be looped with the new radio. On the aftermarket, there is a orange wire that does this. Since the stock wiring is different with every make and model of auto out there, you need to buy the wiring kit that plugs into the car's harness and matches in color to the harness of the new radio. Putting together the orange wires will give you back your lights. If this person cut the orginal plugs off of the car and wired it direct to the car, you may want to see if the plugs can be put back on and the wiring kit installed or you going to be going through a nightmare of figuring out what wire is what on the car side. Those wiring kits that plug into the car and wire up to the radio are cheap and can be bought at Wal Mart for about 20 to 25 dollars. Good luck
Aug 09, 2009 | 1999 Honda Accord
Uninstalling Vista Transform Pack
I did some research for you and MS did a number on everyone with this can't uninstall it and even the people (engineers) who were capable to remove it still have some of the properties left over. From what I gathered go to Windows Explorer. Find the Transform Pack folder and delete it and all of its third party guy even wiped his hard drive and reinstalled, no is to do the delete from C: drive. Good luck..
As a fellow tech support helper you understand the importance of ratings..please rate this solution before logging out. Thanks in advance, if you have any questions let me know.
Feb 05, 2009 | Microsoft Windows XP Home Edition
Zenith rear projection 60 in a60m91w1
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 14, 2008 | Zenith IQB60M92W 60" Rear Projection...
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Sep 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony STR-DE845 Receiver Logo
79 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
