Over the stove microwave is making a terrible noise. Normally the microwave would have two cooking noises. A high energy sound vs a low energy sound. Now one sound has a violent rumbling/electrical noise
  • jerryderango Nov 04, 2008
    GE microwave JVM1660SB005. Everything seems fine except when trying to cook a severe electrical sounding noises starts on one of the cycles.
    I appreciate the direct reply
  • 728 Answers
If your microwave has it, it may be coming from the rotating bottom plate's motor. It may need greasing and/or repair. If it does not, you may have an electrical short that is causing it to make that noise when it is on for a while.
Posted on Nov 04, 2008
    Sergeant:
    Champion:
  • 324 Answers
Sounds like a high voltage circuit problem. Either hv transformer or diode or capacitor or magnetron.
Base on my experiance the hv diode is probably blown. if you know where it is you can look at it see if it is broken in half. should be a small black thing that is screwed to ground.
make sure mw is unplugged first
  • 3,037 Answers
The microwave should be replaced especially if under warranty. Ge is known to have very low quality microwaves and most likely the magnetron is making the noise and may even become hazardous. I recommending getting rid of it and getting a non Ge brand of microwave
    Genius:
  • 1,550 Answers
I dont know what is your problem ?
Is this some thing related to PDA ?
Or
Some kitchen appliance .
If it is kitchen appliance provide details about your model and brand .
Also how old is your unit ?
  • SAM ANDERSON Nov 04, 2008
    You need to replace High voltage capacitor.
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Sharp sound bar buzzing
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Hello, my foodsaver vacc 550 makes a lot of noise while sealing. How can I reduce the noise.
follow this steps and fix it. GOD BLESS YOU
Sep 30, 2013 | Kitchen Appliances - Others
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Microwave makes sound like something moving inside
    follow this steps and use the VOM , and fix it. God bless you
    Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
    The oven has trouble ligting,and make,s a boom sound when lighting
    Magnetron
    If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Enter your model number to see parts for your microwave.
    Help me find my model number
    Exhaust Fan Motor
    If the microwave is loud when running the fan motor might be
    Stirrer Motor
    If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor
    If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Apr 02, 2013 | Microwave Ovens
    Coleman EB15A - Buzzing noise from transformer area, no heat or fan
    see this causes and proceed. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 18, 2012 | Microwave Ovens
    Microwave oven has become very noisy
    Oh, this is a UK/European model...
    I have no info on that, so your best bet is to contact Panasonic UK:
    http://www.panasonic.co.uk/customer-Support/index.asp
    Good luck.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Feb 25, 2008 | Microwave Ovens
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
