Question about Symphonic SC313D 13 in. TV/VCR Combo
Power shut off
TV/VCR turns on but about 10-15 seconds after it turns on it shuts off. everything looks to be fine on the component board. When i took it apart there was a belt broken so i put a new one on and after that the tv turns off after it has been on for 10-15 seconds.
  • toddahhhh Aug 29, 2008
    I have a symphonic TV/VCR combo, it has been stripped and modded into a dart machine, I had to ditch the vcr portion to make it fit. The unit powers up and works, but goes straight to trying to eject the tape, 10-15 seconds and it shuts down. I figure it is looking for the non-existent VCR, is there a way to jump out either the vcr plug or something on the board to make it not look for the vcr or to tell there is'nt one?
    Sergeant:
  • 337 Answers
The set is still sensin a problem thats why it shuts off, in this units the problem is in the vcr section,check the cassette assambly sometimes is jammed and it will not load or one side of the cassette tray is pushed in too far or misaligned.It will continuo to shutdown until the problem is corrected.Be careful when working on it.
Posted on Oct 02, 2006
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
I have taken the back off of this, cleaned everything and cant find out what is wrong. My TV is having a "bow tie" affect and the colors are off on the outsides of the screen but the...
MOST OF THESE SETS HAVE A DUAL SETUP YOU NEED TO REPLACE BOTH @ THE SAME TIME,IF YOU REPLACE THE 1 IT PUTS TO MUCH STRAIN ON THE OTHER AND YOU END UP WITH THE SAME PROBLEM HOPE THIS HELPS
Jul 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv wont turn on
yes that wire which got loose needs resoldered [properly and main board fuse needs to be checked.if not familiar with checking the board with a meter then just call a service repair person as the cost of soldering will be very negligible.
Mar 05, 2009 | Televison & Video
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Emerson EWC 1302 Tv/VCR combo shuts down
As I told you, when the tv main chip detects a problem, it force the TV in protected mode, and activates an internal safety switch to turn tv off.
This is why TV goes off in ten seconds.
when this happens TV must be taken apart and inside component tested and eventually replaced.
The technician will test the inside of your TV starting from the power supply board.
If you want to do it yourself you will need experience in testing and precision soldering, otherwise call a repairman using the phone number listed in the user manual.
Sep 15, 2008 | Televison & Video
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
T.V. shuts off
try unplugging it from the wall for a day
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 06, 2008 | Panasonic PV-C1321 13 in. TV/VCR Combo
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Symphonic SC313D 13 in. TV/VCR Combo Logo
302 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
