Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Another IR Sensor problem (I think)
Like the other gentleman, my TV last night started to only respond sporaticly to both the TV's own remote and the Sat remote. It hasn't quit all together but it is definitely on it's last gasp. Is this a user replacable item or is it time to shell out some cash for a repairman?
    Sergeant:
  • 337 Answers
If you get to the point where you can not use the remote anymore you will need the help of a repairmen to replace the remote receiver but before He does he needs to check if the receiver is receiving the necessary voltage to operate.
Posted on Oct 02, 2006
My TV is not responding to my remote, How can I fix this?
Check and replace its remote control sensor [IR sensor], inside the TV. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2015 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Vizio tv remote not responding
possibly bad batteries in the transmitter. could also be a blocked IR receiver at the TV(do you have something in front of the IR receiver in the TV?) last resort could be either IR receiver PCB or the MAIN PCB.
Mar 03, 2015 | Vizio VW42LF 42 in. LCD HDTV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Tv remote quit working
The remote put out IR (INFRARED) signal that human eyes cannot see, you need to use your digital camera to see it, just point the remote at the camera's lens, you should see flashing light on your camera screen when any remote buttons is pushed.
You may have problem with the IR receiver in your TV, but find out first if the remote is putting out the signals
Parts:
http://www.shopjimmy.com/vizio-3642-0022-0189-ir-sensor.htm
worst case will be the main logic board.
http://www.shopjimmy.com/catalogsearch/result/?q=VX32L
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | Vizio L32 32 in. LCD HDTV
Ok...so the remote works...now what
If the problem is the IR sensor, then the TV will turn on and work using the buttons on TV, but wont react to remote.
If instead the TV does not turn on all all , then the TV is on protection because of an internal fault , and must be tested and fixed by a technician.
Replacing IR sensor is not complicate, but t is not an user level operation.
The IR sensor is usually located on the front bottom side of the TV, therefore to replace it you need to remove the main board completely, and many other parts.
Additionally on many models the sensor is soldered to the digital board.
If the TV goes in standby, then it is in protection mode.
You can get parts below:
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 04, 2009 | Philips CCC130AT 13 in. TV/VCR Combo
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
My TV won't respond to the remote control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Sep 03, 2007 | Philips PR0930X 9 in. Portable Television
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
