I have my computer hooked up to my tv but when i go to play music or anything like that there is no sound. I jave the audio cord hooked up but still no sound. what should i do?
I just went in to my sound settings and reset them for what i needed
Posted on Nov 04, 2008
How do I fix my ps4's audio stutters. I have it hooked up directly to my SANSUI HDMI tv via HDMI cord.
Could it be the internet connection sometimes is not fast enough? or someone else is downloading from the net the same time, or just streaming music or video over the net. All kind of reasons why the sound could stutters.
Sep 11, 2014 | Video Game Consoles & Games
Cant get sound from laptop to tv
Just to verify...you've made sure that your headphones jack will play audio in lets say, some headphones, or a set of computer speakers?
However, your T.V. may not recognize audio when using VGA. I say this because if you look at the hook-ups on your T.V., you notice that most sections contain audio and video together, not seperate. If the port is available on your computer, trying using HDMI, the single cord for HDMI carries both sound and video. One last thing you can try with your current set up is find a set of the red and white rca hookups that are independent of any other grouping, in other words excluding the yellow video or any other connections. If you're T.V. wont play the sound in that, then either your headphones jack is messed up or the T.V. just wont recognize it while using VGA.
Nov 21, 2011 | Computers & Internet
I have Polk Audio TSi500 speakers running through a receiver. They sound fine when the radio is playing from the receiver, but when I try to play music from a computer the speakers sound muffled. I have...
Phono jacks are specifically to hook up a turntable to an amplifier (which is what I assume you mean instead by "receiver" ). Most amplifiers have a receiver (radio) section, but they can be separate components. Anyway, try hooking it up to an auxiliary (AUX) input on your amplifier instead. This may be all you need to do. Good luck!
Feb 13, 2011 | Audio Players & Recorders
How do you transfer music to your lgt300 phone?
The first thing you need is a microSD memory card. Your phone supports up to a 4GB size, so dont buy anything larger. Second you need to hook it up to your computer with your micro usb cord. The phone should have some sort of mass storage mode that will allow you to drag and drop your music files onto the phone. Your phone plays .mp3's and AAC audio.
Nov 30, 2010 | Cell Phones
Got a svga/hdmi cord and hooked up for my panasonic viera plasma to my computer but nothing shows on my component 2. also wondering if i'll need a cord for audio - i have double red/white/yellow...
You probably would need the extra audio cords seeings as normal svga connection won't suppost sound streaming. mixing and matching connections is always a pain to perfect.
If you are using the HDMI end on your plasma, then you will have the video show up on the HDMI channel. Then get an RCA red and white pair - 3.5mm jack and plug the jack into your PC's audio connection port and the RCA's into the Audio In ports in the back of the TV.
Once done the TV should display video and play sound from the PC. Failing this, try a few different configuration but always keep the audio plugged into the same Audio in port on the TV. Bacause then you at least know the channel that the audio works on ;D
Hope this helps mate, any more q's just ask!
Nov 23, 2010 | Panasonic Viera TH-50PX80U Plasma TV
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Panasonic KX-T7730-when receiver on hook plays on hold music
walk up to the phone and without touching anything else, press "1".
No music.
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
Audio Trouble hooking PS3 up to HD
Hi there, Have you checked that the HDMI Cable is inserted into both your PS3 and HDTV correctly ? if the cable moves about in the HDMI port that causes static sometimes ! Also check that your cable isn't damaged.
If the problem persists. i would just Use your Composite (Red,Green,Blue) connection from your TV to your PS3. you said it doesnt have static problems. and Using the composite cable you can still get the Full 1080p Resolution on your TV that the PS3 can Up-Scale to!
Hope this Helps ?!
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
