Question about Konica KL-3015 Laser Printer
KL-3015 paper jam at lower paper tray
There is a semi-circle piece on top of the paper drawer that draws in the paper (on the left top side). There is a black rubbery substance on the circular part of this piece that has become very sticky and gooey. Everytime I go to print, the paper being drawn in from the tray gets stuck on this gooey piece to cause a jam. I can't find the name of this piece in the manual to try and order another. Is there something I can do to just clean the gooey rubber part, or a rubber piece to replace on the semi circular part? Or give me a name of the part and where to order! Thanks!
  • gpacker1951 Nov 04, 2008
    I've found the part name and number - 08AA40050 Paper feed delivery roller
    can I just add a thin sandpaper over the sticky part to grab the paper?
  • gpacker1951 Nov 05, 2008
    ok no offers of help - so here's what I did. I took a piece of 220 grit sandpaper. I cut a piece 3/4" wide to fit the width of the paper feed delivery roller. I stuck it carefully on top of the sticky gooey mess on the semicircular part of the paper feed. It stuck right on there! I replaced the part into the printer....and lo and behold! I'm back in business! Still looking for a replacement part tho in case anyone knows where to get it.
Hi, the roller is available from this link. http://www.precisionroller.com/search.php?add2cart=19976
Posted on Jan 09, 2009
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
Plug wires and distributer cap
for the 1.5L -1.6L- 2.2L and 2.3L ENGINES. from left to right engine cylinders is 4 3 2 1 .now at distributor cap .get a piece of paper draw a big circle now at top of circle from left to right will be 2 then 1 from bottom of circle left to right will be 4 then 3.thats where you will put your plug wires.now the circle you draw 2 upper left of circle 1 upper right.at bottom circle 4 lower left of circle and 3 at lower right.
Jun 26, 2009 | 1995 Honda Accord
F63 OHT Sensor - Konica KL 3015
If you like to know how to fix the Problem F63 you should contact me and join my assistance plan for 19,95 $ a month. Or you fix the problem yourself
Take a Q-Tipps and brush inside the littel hole/slot below the OHT-Sensor Lever on the left side of the paper pass.
Have some fun with this free advice.
....see ya
Jan 05, 2009 | Konica KL-3015 Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Konica KL-3015 Laser Printer Logo
110 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
