Question about Alpine Car Audio & Video
I hooked up a 4 ch alpine amp MRP-F600. The back speakers play nice but the front speakers play very low. What could be the Problem?
    An expert whose answer gotĀ voted for 100 times.
  • 59 Answers
1)When you connected the amp to the head unit, did you run two pairs of RCA cables for front and rear reference or did you only run one set of RCA cables from the rear out to the amp?  2)If that's not the case and you did ran two sets, on your amp, swop the rear and front RCA cables. If the rears go quiet and the fronts are loud you now know the issue is either in the cables or how the head unit is set up. If the fronts are still quiet, check your Amp's gain, frequency and filter setter settings (if available). If those settings don't change anything you may have a faulty amp. 3)Check speaker connections, seems trivial, but you never know.
Message me back if nothing works and/or you get stuck.
Posted on Nov 04, 2008
My mrp m650 alpine amp power light is on but no sound. it works if i hook it to other vehicles but not in mine.
Check your speakers and speaker wires to make sure you have no shorts or grounds. Not knowing what vehicle you are putting the amp in, there is also a possibility that there may be a stock amp in the vehicle. If this is the case, you may have to rewire the speakers and bypass the stock amp.
Feb 27, 2012 | Alpine MRP-M650 Car Audio Amplifier
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Tri-mode amplifier hook-up
you dont have to have a crossover to hook up ur amp 2 ur subs
Feb 27, 2010 | Alpine MRP-F600 Car Audio Amplifier
I have two type-rs hooked up to a mrp-m1000 and its not hitting hard at all! but when one is hooked up it hits harder than two... so is it the way its hooked up or do i need another mrp-m1000 amp? or can i...
If the speakers are rated at 500W or greater, then you'll need two amps to get their full potential. When you connect two to a single 500W amp, each speaker only gets a max of 250W. Also, check the ohm rating for the outputs of the amp and the ohm rating of the speakers as well. Unmatches speaker/amp impendence also results in poor performance. If you connect two speakers to one terminal, the total impedence of the speakers falls by 1/2 (two 4 ohm speakers wire together will result in 2 ohm impedence). So, if you have an amp rated at 4 ohms, you could connect two 8 ohm speakers to a single output. Hope this helps some!
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
Car Audio & Video Logo
85 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
