Question about JVC AV-27D303 27" TV
JVC 27" The top 2" of my screen is black. Below that the screen has 2" of white lines that appear to have missing portion of the picture upside down,(like a ghost image folded over). Is this worth a repair or should it be replaced?
    Novelist:
    Champion:
  • 275 Answers
Repaiur or replacement? It's Your call! If you know Solid State repairs, then worth a try. Most likely a bad Electrolytic capacitor in the Vertical Oscillator / Output section. Do not waste time identifying faulty one, but change all at one go. Even if one is faulty, the others must have started drying up, and will cause problems in the future.Remember "An Ounce of prevention is better than......"
Posted on Oct 02, 2006
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Mar 21, 2009 | JVC AV-27D202 27" TV
Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Sep 10, 2008 | Philips 27PT6441 27" TV
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Top section of the picture gets reversed and compressed
Dear simon, Seems like a simple problem. In all likelihood, one of the Electrolytic Capacitors in the vertical Output stages has failed.It could also be a cold / dry solder, as symptoms seem to disappear when you tap the set. But, do not try anything thing at home. A proffessional Techie should fix it up in 15-20 mins. Definitely worth the spend.
Aug 02, 2006 | JVC AV-27230 27" TV
JVC AV-27D303 27" TV Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
