Question about Frigidaire Washing Machines
Water collects in bleach and fabric softner compartments on my fr he fl ltf8000fe
    Sergeant:
    Champion:
  • 324 Answers
Did you try cleaning the dispenser out.make sure the part that goes in the drawer sits properly,the water fills and causes a siphon.if this siphon does not happen water will stay in the dispenser.
Posted on Nov 04, 2008
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Jun 18, 2008 | GE WBVH6240F Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
173 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
