Question about Zenith SY1931SG TV
Cannot access menu
I cannot access the menu on my Zenith SY1931SG via the remote or front panel buttons. All other buttons on the remote work (mute, volume, channel, flshbk) and the volume, channel and power buttons on the TV work. Ideas?
  • Anonymous Mar 25, 2014
    Both tv and bright house' remote just stopped working for the volume and on/off...
    Sergeant:
  • 337 Answers
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
SOURCE:
Can i use a rca universal remote to reset the lamp timer on my Zenith D60WLCD 60" Rear Projection HDTV-Ready Television? I have lost the original remote and have replaced the bulb
Probably not. You need to get into the "utilities" menu, which is only accessible via the original remote (or possibly via buttons on the TV).
Apr 07, 2015 | RCA Televison & Video
How do I program channels into my Zenith sy2551s tv without a remote control? Thank you!
If your TV has a "Menu" button on its front panel, you can press it, enter its menu window, select auto tune function, and press Vol+ button. If it has no Menu button on its front panel, you must ahve its remote control to select this function.
Mar 31, 2012 | Zenith Televison & Video
The remote control for Zenith TV Model No. SY1931SG was lost during a move. Can't find site where I might be able to replace it.
You can get an adequate Universal remote at a dollar store, or a general dollar,
or a dollar general, or an ollies, or a big lots, real cheap.
And you might be able to use it for everything in the house!!!!!
Please COME BACK AND RATE!!!
Aug 31, 2011 | Zenith SY1931SG TV
Need the original settings for an 42 LE 530 tv
they is no reset botton .
to reset -switch off your tv from mains plug leave it off for 5mins and switch the tv on.
You may need to purchase a programming remote from LG. The user remote that comes with the TV doesn't have the MENU button. The manual also listed a programming/cloning box by Zenith, I have a cloner box for RCA and it has a reset button on it. I had to download the manual for the same TV from http://shop.retrevo.com/ they didn't have a listing for the LG but the Zenith has the same model # and is the same TV as far as I can tell. You may be able to access the menu using the menu button on the front of the TV . Hope this helps.
Apr 14, 2011 | LG Televison & Video
The volume won't stay up. When I turn the volume up, it immediately goes back to zero...and the volume display is permanently on
your TVs front panel control swwiches are in trouble. Replace all of the at the same time will resolve the problem.
Oct 15, 2010 | Zenith SY1931SG TV
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Televison & Video Logo
106 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
