Question about Toshiba Satellite A25-S207 Notebook
Need help think i may need a motherboard
Hi well when i turn on my laptop it starts up for a few seconds then shuts its self back down.
    Problem Solver:
  • 8 Answers
Dc power jack problem.
solution = local experienced computer tech that can solder
the broken dc jack pin back to the motherboard.
Posted on Feb 17, 2008
    Novelist:
  • 114 Answers
If the the laptop is failing to boot very early in the4 boot sequence, then this usually points to a failure somewhere on the motherboard. There are a few test you can run to try. 1) Try downloading the following Diagnostic program and running it on your computer. The download makes a bootable CD, and you can try running a bunch of diagnostics on your computer with out having to boot into Windows. You can test memory, the hard drive, and other things. http://www.ultimatebootcd.com/ 2) Try replacing the memory. Sometimes bad memory can cause a device not to boot. 3) If neither of the above suggestions work, then I'm afraid you will need a new motherboard.
Posted on Oct 02, 2006
Turbo button
down of your processor there will be a cool paste i think it is gone so apply cool paste it is available in computer shops
Sep 25, 2013 | MSI Computers & Internet
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
I have a dell ins iron 1521 and yesterday it started running lines accords the whole screen and making some sort of noise. At the time my son was playing farmville on it. We had to shut it down, not we...
This is most likely a video graphics failure (just like the lines that you saw when computer is still running). For some dell computers, specially a laptop, the graphics card is built in to the motherboard. For the computer that blinks for a few seconds and turning itself off, the computer is no longer performing it's POST (Power on self test). If the computer is under warranty, try contacting Dell or if not, try contacting a local technician to have the motherboard replaced.
Jul 03, 2011 | Dell Inspiron 1521 Notebook
My laptop has a problem. If I put it on, it stays on for a few seconds and then shuts off, and then comes back on for it's self for a few seconds and shuts off and continues to do this. To stop it I...
you have not stated the model but try rebooting whilst applying some pressure where ever the the cpu fan is mine was at the top right and found that the continuing heating up and coolind down of the processor had caused bad solder joints if this is the case you will need a really strong magnifying glass at least 10x and a pin point soldering iron to repair it
May 30, 2011 | Acer Computers & Internet
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
Hi
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
Laptop sIt turns on, but shuts down after a few seconds. It will not boot from cd either?
Hi, Lucas
You may have a RAM chip issue or at worst a motherboard problem. On the Microsoft website, they offer a memory test tool that you can download and run to test the RAM in your laptop. If you have a way of checking your RAM chips on another laptop you can use this method as an alternative to the memory test.
Let us know the outcome.
Chris
Jun 29, 2008 | Toshiba Satellite A60 Notebook
Laptop keeps shutting down, both fans not working
sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
May 25, 2008 | Dell Latitude C640 Notebook
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
Toshiba Satellite A25-S207 Notebook Logo
813 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
