Question about Sony PCG-FXA35 Notebook
Cd/dvd drive sony pcg-fxa35/d notebook cmptr. cd drive does not work. the drive e does not show up in my comptr listing.
  • kuba11241 May 18, 2009
    Hi is there anyone ho can send me drivers for cd/dvd graphic and keyboard please i need it very much my email kuba11241@gmail.com Thank You
Hello, I am contacting you on behalf of my cousin whose computer crashed. She has a system restore disk and I instructed her to reset the order of start up in the BIOS by moving the CD/DVD drive to the...
One of the function keys should get you into the boot menu, F9-F12, to manually select the CD/DVD drive. Pressing Esc or Tab on VAIO logo may display the right information to show which key to press.
Have you tried booting a standard Windows setup disc and checked if the hard disk is working ok?
Aug 24, 2011 | Sony VAIO PCG-K33P Notebook
Remove and install cd/dvd sony pcg-f520
go to the device manager then under cd/dvd drives, right click to the driver then click on uninstall.. restart the computer then it will reinstall automatically
Apr 07, 2010 | Sony VAIO PCG-F520 Notebook
I have installed a new hard drive in my Sony Vaio PCG-K35. I want to install the OS but the dvd drive is not reading the disc. The light stays on and does not flicker as it does when reading data. Is the...
Hi there if its only a DVDS player then you can't access CD on there. But if its DVD & CD both player then there is a chance of drive damage. I suggest you install NERO cd/dvd reader software after thsat use those CD or dvd. Thanks
Mar 21, 2010 | Sony VAIO PCG-K35 Notebook
My vaio cd disc drive needs to be replaced
I have vaio DVD/CD writer.
Sony CD/DVD Unit model AW-G540A it was removed from a Sony Notebook laptop Model PCG-9U1M. The Unit was working perfectly until the laptop was dropped and the screen was damaged,
You can find the specification on the net.
Let me know if it’s suitable for your laptop or if you are interested.
Feb 17, 2010 | Sony VAIO PCG-K35 Notebook
My sony vaio model pcg-7y1l is not working. When
i had the same prob this morning there are 3 things you can try
1 memery
2 proccessor
3 hard drive
if not any of them
try the dvd drive
if not that then try exsternal monitor if dont show on that then motherboard is gone
Aug 14, 2009 | Sony VAIO VGN-AR230G Notebook
? Sony VAIO - PCG-GR390 ? Changed hard disk, ? Application & system recovery CD not working, its worn out. ? Installed retail ver of Windows XP ser.pack-2 ? Modem, display, LCD drivers not...
if your disk is worn you have to buy a new one from sony with the original software on it. there is no other option
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
May 14, 2009 | Sony (PCGA-RDVG1) for VAIO PCG-GR300,...
Device Manager found a problem with the driver and can not be fixed automatically. Need to download the Integrated CD-RW/DVD Combo Driver.
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Hope this helps
May 04, 2009 | Sony VAIO PCG-K23 Notebook
RAM up date
do you have a the memory on hand, or you want us help you to get it and installation procedures/details?
Jan 15, 2008 | Sony PCG-FXA35 Notebook
Sony Vaio pcg-frv37 dvd rom not working
you need a DVD burner in it to play and Burn DVD's
you have a CD Rom in it now.
Dec 17, 2007 | Sony VAIO FRV37 Notebook
Sony PCG-FXA35 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
