Question about Gateway GT5220 PC Desktop
Constantly reboots itself
Computer boots up then immed shuts down then reboots again and keeps doing this, also video is extremely out of wack, updated to sp3 started about 2 weeks after that, got on long enough to restore back to sp2 still not working, boots in safe mode can do what you want but video starts to get lines in it then everything gets distorted
gateway gt5026e desktop
  • cmcookeville Nov 04, 2008
    updated to sp3 after finally getting past access denied error, about 2 weeks later video started going to 600x800 by itself reset back worked fine for couple of days then do it again then just last two days video on monitor so bad cant see and windows boots just as all start up programs load it shuts itself down then re-boots itself and will keep going thru this process over and over until you manually shut it down
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    SP3 has had its share of problems. Trouble is when you try to uninstall it, it doesn't work...completely. I had to do a full recovery the first time I tried installing it. Nothing I did helped.
    Novelist:
  • 100 Answers
The Gateway GT5220 has an AMD Athlon 64 processor. It has been documented that Windows XP SP3 doesn't play well with some AMD CPUs. I'm pretty sure this is one of them. I would suggest attempting a system recovery using a restore point on a date BEFORE you installed SP3. If that doesn't work, you might consider recovery using the original Gateway Restore CD. It will likely wipe the system, but that might be the only choice.
I would NOT start with the total reload option. We have a couple others before you get there, so try the restore point and then let me know the results. We'll go from there...
Regards,
Char1ieJ
Posted on Nov 18, 2008
My E5430 laptop will not reboot - tries to and then shuts down
Can you boot into diagnostics without it shutting down? Try it while plugged in and the battery removed.
Jun 25, 2014 | Dell Latitude E5430
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
Mar 12, 2017 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
Virus...need to reboot
hi.. shut down ur system. re start again. hen ur computer restarts keep pressing F1 key. it will auotomatically guide u to the re boot process... the F1 key is also called as boot menu key..
pls rate me
Jan 21, 2009 | Averatec 1000 Notebook
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
COMPUTER KEEPS ON REBOOTING ITSELF.
Supose you have allready tryed to change "restart the computer" to "shut down the computer" when you shut down the computer?
/Teis
Jan 04, 2009 | Computers & Internet
My computer keeps rebooting and will not even let me start it up in safe mode.I blew the dust out of it and it restarted and let me into the desk top for about 5 minutes but then shut down before I had a...
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
Oct 22, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Re boots itself
when you turn on the pc keep pressing F8 and it will boot into safe mode. When in safe mode highlight the option 'Last Known Good Configuration' and press enter. The pc should now reboot normally, if not you will need your installation cd to do a system repair.
Mar 18, 2007 | Acer Aspire 3000 Notebook
Gateway GT5220 PC Desktop Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
