Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cartridges wont align
I keep getting "press enter to align catridges" in the window. I keep pressing enter but that doesn't fix it. How do I fix this
  • dipietro06 Nov 05, 2008
    I was unable to align the new cartridge. When I pressed "enter", it would try to do the alignment and then give me a message that it was unable to align the cartridge. I resolved the problem by using HP ink cartridges rather than the generic cartridges from Ink Stop; I only had the problem when using the Ink Stop cartridges.
  • tripwire45 May 11, 2010
    Are you saying that pressing "Enter" doesn't align the cartridges or that pressing "Enter" does align the cartridges, but the message doesn't go away?
    Scholar:
  • 87 Answers
Could be one of two things....
1 - as the person has already posted, you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Posted on Nov 06, 2008
After replacing the cartridges, it doesn't print. Is there a problem with the head as the printer was not used for a long while
After installing new catridges, try to goto the printer options. in the serives option do the ALIGN THE CATRIDGES. then it will aligh the catridges correctly and it may print.
This procedure works for some models of printers.
Jun 14, 2011 | Office Equipment & Supplies
I just changed my black ink cartridge and I keep getting a message that reads: pree enter to align catridges. Each time that I press enter the test runs and the screen reads alignment failed. HELP
Hi
in order to get alignment you need to have ink
in both cartridges
You need to replace and color cartridge or refill it
like this
If I help you pls vote me
Sep 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cartridges alignment problem
To align catridges:-
  1. Load plain paper.
  2. Press the Menu button, and scroll to Align Cartridges.
  3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete
To do it from your computer:-
  2. Open the lexmark Series Utility.
  3. From the catridges tab, click align catridges.
  4. Click OK to print alignment page.
  5. This will be make the alignment successful. If not successful, it should be done manually.
Aug 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Align Print Cartridges
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Nov 10, 2008 | HP Photosmart 2710 All-In-One InkJet...
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
126 people viewed this question
Ben Johnson
