Question about Microwave Ovens
Sharp Convection oven, about thirteen years old, died while working... No electricity seems to be flowing anywhere into the microve convection oven. Does it have a fuse that might have blown, or is it more likely that it has died a sudden death and should simply be replaced? Model is R9H84B manufactured in October 1995
  • ronneuen Nov 04, 2008
    Sharp Convection oven, about thirteen years old, died while working... No electricity seems to be flowing anywhere into the microve convection oven. Does it have a fuse that might have blown, or is it more likely that it has died a sudden death and should simply be replaced? The real problem is that it is mounted in our cabinets and it has pieces that make it a perfect fit in them. It may be extremely difficult to find a replacement that has all the mounting brackets.
    Thanks... I needed a solution that would keep me going.. I will take the oven to an appliance repair shop now...
    Ron
    Genius:
  • 2,035 Answers
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Posted on Nov 04, 2008
    Genius:
  • 1,550 Answers
Chance of fuse being blown . But i think it is time to replace it . It will be not only be the problem of fuse . Due to aging of components can cause you lot of trouble . Go for new one .
Sharp Convectional microwave oven model R990K (R980J) working but convection not working only getting to 70 degrees what are the common problems causing this?
Don't know model but the convection uses a coil and fan( if electric) if gas , flame and fan. I guess you have electric and have a bad coil
Mar 03, 2015 | Sharp Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Convection starts ok, but quits after 10 minutes. It's 11 years old
Trying to calibrate mu sharp 32LE700UN. Settings are as follows:'
OPC is off, baklight at +14, contrast +30, brightness +2, color +2, Tone 0, sharpness 0, CMS Hue +12. Are there any settings I am missing or need to change to get the best picture? Also, color temp at middle and AV Mode at Standard.
Dec 16, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
Manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Jun 13, 2009 | Sharp R-820B Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Cooking in an old convectional microwave
Regardless of the model, the basic procedure should be the same in most Sharp convection models.
You can download several recent models here:
http://www.sharpusa.com/products/TypeManuals/0,1083,5,00.html
Nov 22, 2007 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
