When turn off the computer Windows shoot down, but monitor and coolers still working! Last message on screen is "Windows is shuting down.." and than just stop. only way to turn it of is to press a Reset button or just to unplag power cable. I have EP-8K9AI motherboard, 768mb of RAM (512mb+256mb), witch also sometime working both,but ussually just card in the right slot! If anyone have idea what's happening, please help!!!! Thanks!
I also find out somethin interested about RAM memory, old card was 256MB an it been palced in 1st slot! When i get new (512MB), i placed it in 1st slot, and old move to 2nd slot! Since I do that, every restart was lotery, machine sometimes seenone card (512MB from right slot), sometimes both! I simply change their palces na problem desapired. Now computer work perfectly with bouth cards! Thanks for help abouth shuting down!
You can't post conmments that contain an email address.
You have a System file problem Go to C:\ right click go to properties tools "error check" click to open then tick little box to fix errors and reboot . Windows on reboot will scan disk and fix any errors. If this does not fix it reinstall windows in "Repair Mode" Boot from Win CD after drivers etc are loaded will ask you what you want to do Press the R key to Install in repair mode. you will not lose any files doing so
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
> couldn't get it to work with an external ... monitor
With the computer turned-off, connect the monitor to the SVGA port.
Turn the computer on -- the usual "start-up" messages should flash on the LCD screen.
Or, take the laptop into a darkened room, to see if the usual Windows "desktop" icons & wallpaper are dimly visible.
Or, take the laptop & the power-supply to a qualified technician, for professional trouble-shooting.
The short answer....reinstall windows. Yes you well loose what is on your hard drive, but atleast you can use your computer.
Need more help? Let me know.
Good Luck!
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
If
the monitor screen remains blank (no startup screens or onscreen
display messages), the monitor must be connected to another computer
using a different cable to determine if the monitor is bad. Skip to the
Step to connect the monitor to another computer.
If the monitor is capable of displaying boot screens but is unable to
display Windows, use the following steps to set the computer to a
compatible resolution:
NOTE:
Find
the native display resolution for your monitor in the User Manual or in
the product specifications for the monitor model. If you are unable to
find the native display resolution for your monitor model, temporarily
use 1024x768 for troubleshooting purposes.
Turn on the computer and press the
F8
key repeatedly when the first startup screen appears.
If you are using Windows Vista, select
Enable low resolution video (640 x 480)
, press
Enter
, and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document,
Changing Display Settings, Background Image, and Screen Saver in Windows Vista
If you are using Windows XP, select
Enable VGA Mode
, press
Enter
, and wait until Windows opens. Continue using these steps to set display resolution.
If you are using Windows 98 or ME, select
Safe Mode
and perform the following steps to enter into a standard VGA mode:
Once Windows opens to the desktop in Safe Mode, click
Start
, and
Run
In the Open field type
msconfig
and press
Enter
The MS Configuration Utility window appears.
Click the
Advanced
button, and select
VGA 640 x 480 x 16
if it is available.
Click
OK
and restart the computer.
After Windows opens, click
Start
, and then click
Run
msconfig
and press
Enter
Click the
Advanced
button, and remove the checkmark next to
VGA 640 x 480 x 16
Click
OK
. Do NOT restart the computer.
After Windows opens, right-click on an open area of the desktop and select
Properties
(Windows XP, 98/Me) or
Personalize
(Windows Vista).
In Windows Vista, Scroll down and click
Display Properties
In Windows XP, 98, or Me, click the
Settings
tab.
In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to
Highest (32 bit)
In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to
Highest (32 bit)
In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to
True Color
Click
Apply
after you have made your adjustment.
The screen should blank out temporarily and come back.
If you are satisfied with the new display settings, click
Yes
on the Monitor Settings windows. If you are not satisfied or if the
screen just goes black, wait: Windows sets the screen back to the way
it was before. Try another setting until you find a display
configuration that is compatible with the monitor and meets your needs.
NOTE:
If
the native resolution is not available, download and install updated
video driver software for your computer. Updating the video driver
software can add more resolutions (graphics modes).
Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using
a different cable, connect the monitor to another computer that has
video. Turn on the monitor and the newly connected computer. What
happens?
If
the monitor works, the video hardware on the original computer is
likely to be the source of the problems. You can try connecting the
original computer to another monitor that works to update its video
drivers.
If the monitor remains blank, repair or replace the monitor.
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
plz resit the ram,if problem is not solved then try by removing the cable from the monitor to cpu and check is there is any message or white screen in the monitor,if you get any thing then your monitor is ok,otherwise your monitor needs repairing. If you get message in the monitor or the color changes then your motherboard display adapter needs to be repaired
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Lower down resoluction and color quality to minimum on your pc, using 'display properties' in Windows. Connect the monitor back to pc with minimal settings. If it works is done.
If it still does not work there is a major problem with the monitor. In this case It should be opened and tested inside following schematics. In this case you may need to take the monitor to a service in your area.
You have set a resolution that is too high or incompatible with your monitor.
I assume you are using Windows.
Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears.
Use the Up and Down keys to select 'Enable VGA Mode'
Press enter and your screen will work again when windows starts.
Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display'
OK everthing and now you should be able to adjust the resolution without getting a blank screen again!
Good luck and come back to comment soon.
Regards
