Question about Lavazza Espresso Point Capsule Machine
Replaced gasket now I can't find what was plugged in...
My Lavazza had been leaking when I used it. I followed the instuctions on another post and I took out the heating element, and replaced the gasket. I put it all back together and now I can't figure out what was pluged into the lower right hand side, backside of the heater. There is a prong sticking out of both the right and left side of the machine. I have everything else plugged into what seems to be right and there is nothing extra. I am either missing somthing or I have something plugged in wrong. I am guessing I have something plugged in wrong. I have double checked everything. I am pretty good with fixing things so this is driving me crazy. I have learned to take pictures for the next time. If someone can send me a picture or a link to a diagram I would be very thankful.
  • 2 more comments
  • janetcampolo Nov 17, 2008
    I have the same problem with leaking. Where did you get the replacement gasket/
  • suzi0903 Mar 22, 2009
    I own Lavazza Espresso Point Caspule Machine for six years and never have any problem till now. When I make a coffee, the water is leaking in the drawer. I open the top, run the machine and figured out that water is coming out from heating element. I belive it's a gasket that needs to be raplaced. How can I fix that, and where to get another gasket?
  • Anonymous May 07, 2009
    same for me
  • nadia foster
    nadia foster May 15, 2014
    I was told that I need to replace the solenoid valve and the boiler gasket for my Lavazza EP machine, but I do not know where to find the parts. I'd be grateful for any suggestions.
Do you still have this problem? If you want I can send you a picture of this part.
Posted on Jan 13, 2009
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Jul 08, 2011 | Lavazza 2210
Oil is leaking from enging
Hello and welcome to FixYa!
There are lot of reasons for engine leaks, here are the following:
- Loosen oil drain plug
- Cracked oil pan
- Worn out oil pan gasket
- Worn out valve cover gasket
- Worn out transmission oil seal
Please have the following checked and replaced if necessary. Hope this helps and thank you for using FixYa! Have a good one!
Jun 16, 2011 | Volvo S40 Cars & Trucks
My Lavazza Espresso Point keeps blowing one of the glass fuses, any adsvise?
Typically when this has happened I have found the issue being the plug holder and fuse block. Simply have the Plug Holder and Fuse Block replaced and the issue should be resolved.
Jun 10, 2011 | Lavazza Espresso Point Capsule Machine
I have a Lavazza Point Expresso Machine and it started leaking water out of the front. I believe it needs a gasket, but can't seem to get the parts to come off to get to it. I have used an Alen Wrench,...
When replacing the o-rings inside the boiler the operation should be carried out by a certified technician for these machines. When the boiler is dismantled it is recommended that all o-rings and springs in the boiler be replaced as these are ware parts. When the boiler is apart this is also an opportune time to do some manual cleaning to the internal parts. This is an easy task but as I said before must be carried out by a certified technician. Special tools not readily available to homeowners are required to rebuild the boiler once dismantled. I am sure there are many repair facilities around but location wise I am not sure. I have heard that espressozone.com are nice and will do repairs. Perhaps try them. You may also try contacting a lavazza rep and they may be able to point you in the right direction.
Apr 09, 2011 | Lavazza Espresso Point Capsule Machine
1993 E-150 which is leaking antifreeze. I have replaced the waterpump, waterpump gasket, the thermostat, the thermostat gasket and all hoses; however, the leak continues. It only leaks after the engine...
Hi, it could be your intake gaskets leaking,or a upper freeze plug you can go to your local auto parts store that has loaner tools and use a coolant pressure tester and put pressure on system do not put more pressure then your radaitor cap says . When you pressure test system it will show you where your leak is with out the van running.If i can help you any more just re post.
Jan 08, 2011 | 1993 Ford Econoline
Where can i get a replacement gasket for a principessa lavazza balzono model number 53190B/82
Try a Bialetti spare. I have had success with a Bialetti gasket for this identical model having searched for the correct Lavazza gasket for years. Mine came from from Pumphrey's Coffee in the Grainger Market in Newcastle uopn Tyne, but any Bialetti stockist (it's a very common espresso maker) should be able to get you one. It's probably the 6 cup size you need.
Dec 03, 2009 | Lavazza Coffee Makers & Espresso Machines
Need service on lavazza blue LB 2210
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
Jan 04, 2009 | Lavazza 2210
Lavazza Espresso Point Capsule Machine Logo
552 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
