Question about Bose Lifestyle SA-2 2-Channel Amplifier
Bose lifestyle sa-2 2
The green light goes on 1sec ,goes off 3sec
wiring is ok
speaker are ok
remote control programming is ok
but not sound
  • serate Nov 04, 2008
    how many ohms should be at the speaker terminal
    speaker are bose 191
    President:
  • 624 Answers
Most bose speakers are 4 ohms. Your problem is the amp in protect and will require repair. The only way to get this fixed is to take it to an authorized Bose service center. Bose will not even sell parts anymore to anyplace that is not an authorized Bose service center. They just started this policy a couple of years back and it makes it nearly impossible to fix Bose products, no parts, no service manuals, no support period unless you are an authorized Bose service center.
Posted on Nov 04, 2008
    Genius:
  • 1,913 Answers
Check your power supply waltage and earthing is porper working
  • Bose Master
  • 19,396 Answers
Test the speakers on a different set , the set may be defective or faulty.
If it is not that it is probably a bad wiring, doublecheck.
Posted on Nov 03, 2008
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
How to equalize extra speakers?
The only thing you can do to equalize those speakers. Make sure that you have them in faze. + to + and - to - and left to left and right to right. Make sure that your speaker can handle the ohms. (the same ohms) for example If your amp is rated to handle 8 ohms then your speakers should have 8 ohms. The speaker wattage should also be abit more than what your amp can produce. Distortion is your worst killer of speakers.
Mar 26, 2012 | Bose Lifestyle SA-3 2-Channel Amplifier
We have just installed a Bose lifestyle system, with SA 2 and SA 3 amplifyer, with a second set of speakers in another room. we cannot get sound to the second room. the second remote is not responding....
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Mar 21, 2010 | Bose Lifestyle SA-2 2-Channel Amplifier
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose Lifestyle SA-2 2-Channel Amplifier Logo
190 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
