Question about Rockford Fosgate Punch 700S Car Audio Amplifier
Rockford fosgate punch 700s gets very hot
I got rockford fosgate punch 700s hooked up in two 12" jl w1v2-8 with the rms power of 150w. the amp gets hot in 5-10 minutes of opperation. to avoid breaking neither one of them i will just turn the power off and let it cool. what do i need to do? please let me know thankyou.
  • 631 Answers
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Posted on Nov 05, 2008
I know my was cool when i had it wired regulary but as soon as i bridged it it would get hotter than ****
Posted on Nov 06, 2008
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
    your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
    there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
    when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
    hope this helps
    Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
    Rockford Punch HE2 wiring question.
    if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
    Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
    Ohms load
    u should be able to just dont wire the subs sown to 1/2 or 1 ohm I believe these amps can handle 2 ohms and above
    Nov 23, 2008 | Rockford Fosgate Punch 700S Car Audio...
    Amp gets very hot in as little as 5-10 min.
    Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
    Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
    Old rockford fosgate power 1001bd
    The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
    Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
    Cold weather blown fuse
    You might want to try better quality fuses, or allow the amp to warm up a bit before you start bumping down the street make old ladies angry.
    Jun 01, 2007 | Rockford Fosgate Punch 700S Car Audio...
    Rockford Fosgate Punch 700S Car Audio Amplifier Logo
    337 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    seankane89
    Level 1 Expert
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
