Question about Olympus Camedia Stylus 300 Digital Camera
Memory card error
When turning on the camera it goes into card setup mode and tries to reformant the memory card. Also, when trying to take picture I'm getting a card error message on the LCD display.
The problem seems to be that the card has been formatted incorrectly (probably by your computer, if you used it in a card reader?). Unfortunately the camera can't reformat it itself, and default computer formatting is incompatible. You'll want to download the program Lowlevelformat.exe from this website--http://olypan.quotaless.com/forum/viewtopic.php?t=8, install it, reformat your memory card with it, and the camera will be happy with it again.
Posted on Jul 01, 2007
What specific memory card is required?
Memory cards should be formatted before use. They should also be formatted each time you finish downloading pictures from it.
Jul 05, 2010 | Vivitar ViviCam 3720 Digital Camera
Shutter button does not respond to push. If D-90 camera is turned on, what is the most likely error I am making? Allan Fork afork1@aol.com
There are several possibilities.
Do you have a memory card installed? By default the camera locks the shutter release if no memory card is installed. Install a memory card if you have one, or change Custom Setting F6 to "Enable release" and see if you can take a picture.
What release mode are you in? If the camera is set to one of the remote release modes, it's waiting for an infrared signal from the ML-L3 remote release. Turn the camera off and on again, then try to take a picture.
What focus mode are you in? In AF-S, the shutter will not release until focus is acquired. Try turning off the autofocus (there's a switch just below the lens release button) and see if you can take a (probably blurry, but who cares?) picture.
Does the battery have sufficient juice? Press the menu button, navigate to the Setup Menu, then select Battery Info. If it's below 10%, I'd charge the battery. Of course, if the menu doesn't come up on the screen, that would tell me that the battery probably needs to be charged.
Is there a lens attached? What type? Certain older lenses and others lack the electronics to fully support newer digital cameras. With such lenses, you have to switch to Manual mode. Turn the mode dial to M and see if you can take a (probably an improperly exposed, but again, who cares?) picture.
Are you getting any error messages? If so, or if none of the above apply, then the camera may need service.
Jan 02, 2010 | Nikon Cameras
Card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Nov 12, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Memory Card Error
you need to put what ever is on you card onto you computer then reformate you cardthrough your phone .the card is setup for your old phone
Apr 16, 2009 | LG Vu CU920 Cellular Phone
A little hand with a no sogn through it and the word busy
The busy sign generally comes when:
Image is being recorded to the memory card, or playback mode is starting up.
It possible your memory card is full, please therefore down load your pictures and try again after erasing and reformating the memory card..
Alternatvely, please also reset all the camera ands menu settings to default.
Hope it works for you.
Mar 02, 2009 | Canon PowerShot A530 Digital Camera
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Samsung digimax 130 camera memory error
If memory card is full, just try to delete one picture and try to take a picture and check if it will be saved in the memory card.
There is a Delete All option.
Or if you want to, you may format the memory card and the pictures will be deleted.
Sep 16, 2007 | Samsung Digimax 130 Digital Camera
Memory Card Error
try another laptop (friend's)..I suspect yours has a NTFS hard drive format while the card has a FAT type format. You can see which type by starting defrag and reading screen.
Jun 10, 2007 | Olympus Stylus 710 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
276 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
