Back to:
Tags:
SmartDisk USB Floppy Drive Titanium Edition  External Floppy Drive
No power (by 2 users)
posted by Vern on Oct 01, 2006
I purchased the above item. At first everything was working fine. Then while reading a disk the light continued to flash.Once the disk was removed,additional attempts where tried with the same results. Now even after trying all my USB ports I have no power to the unit.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by imss28, posted on Jun 21, 2008
DEVICE DRIVERS, NOT FOUND BANANA
nO VALID cdrom DEVICE DRIVERS SELECTED
Best Solution
posted on Oct 02, 2007
Thanks for Trying (70)
yobe
Rank:Apprentice Apprentice
Rating: 55%, 1 votes
it can not come on ,PLiz what should i do?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No power:
I don't want to Accept this solution
Solution #2
posted on Oct 12, 2007
Not Rated (0)
katet
Rating: 0%, 0 votes
steps on how to fix the floppy drive if there is no power on it
Thank You!
Solution #3
Not Rated (0)
yobe
my latop can not swict on with battle
and dc? (acer tavelmate 630 p4)
Thank You!
Solution #4
posted on Nov 17, 2006
Not Rated (0)
Keeter
Rank:Master Master
Rating: 85%, 136 votes
Well, the first step in any problem of this nature is to narrow down the problem. We have three main things in effect here, and we need to know which one has the problem before we can fix it.
First, the disk itself. Try other disks and make sure the disk is not faulty.
Second, the usb ports. Try other devices in your usb ports to ensure they are installed and configured properly.
If all of those work, it is narrowed down to the floppy drive itself. If it does not work on any pc's at all, then it definately has a problem, and I would suggest contacting SmartDisk technical support.
Thank You!
Can you Help with these Floppy Drives problems?
Floppy Drives
1. if a rectangle has a length that is 3cm less than four...
Floppy Drives
A positive number is 5 times another number.If 21 is added...
SmartDisk USB Floppy Drive Titanium Edition...
When i put a disk into the unit, it says the disk is not...
I purcASED THE HIGH SPEED 2X FLOPPY DRIVE FOR MY tOSHIBA...
I have a Smart Disk Model FDUSB-TM and have tried to load...
Loading problems.
Repair Service
Find Floppy Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
