Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Washer not going thru cycle
Hello
we have a whirlpool washer and all of a sudden today when we load with wash the washer will start but it will not advance thru the cycle. i am thinking it could be the cycle switch casue it is not turning theu cycle.. please advise
thanks
  • 1 more comment
  • Anonymous Nov 07, 2008
    does not finish cycle
  • mellorraine Nov 30, 2008
    Mine does the same thing.....it starts, fills up with water, and then shuts off. I have to open the lid, turn the dial, and restart for it to continue. It is only 3 years old. Does anyone know what this problem could be?
  • jcball Jan 09, 2009
    i replaced the timer switch and this solved the problem..it was about 80 buck from the applince parts store
    Problem Solver:
  • 15 Answers
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Posted on Jan 09, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
I aded a garment to the wash cycle after it was already started . I pressed start after doing this and my washer would not start again. What can I do to restart my washer?
Hello, Thank You for using FixYa. I will be helping you today.May have messed up the cycle try unplugging unit for five minutes.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL FRONT LOADING WASHER MODEL #GHW9460PL0
I have a Sears front load made by Whirlpool. It had a problem locking door. I replaced latch/switch assembly and still would not work. Took top of washer off 3 or 4 screws on back of machine lift up lid and slide back. Make sure washer is unplugged. Presto you can see wiring and control. Unplugged connectors on control and plugged them back in then tried washer and it works.
Apr 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Jan 07, 2009 | GE WDSR2080D Top Load Washer
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Clothes covered in lint
    You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
    Oct 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    88 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
