Question about Sony KP-51WS500 51" Rear Projection Television
The picture is in black and white but menu is color
My wife droped the cloths basket on the other side of the room and the TV when black and white. The menu is in color but I can't get the picture back to color. The focus goes through the colors but picture is in black and white
  • dwcmac Nov 04, 2008
    Well I found the problem about 1/2 an hour ago. The S-cable in from the dish box was loose put in a new plug and got my color back.
    Genius:
  • 2,920 Answers
You might have the colorwheel checked to see if its bad
Posted on Nov 03, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
HLN507W picture is in black/white what componet or board is bad
Turns out wife bought a 5 yr service plan...I didn't know about...it expires in march...WoW; what luck. Tech is 90% sure it's the color wheel
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
Black and White instead of color
Make sure both S-video (black round connector) and Composite video (yellow connector) are connected to video outputs not inputs. It can also be the S-video is disconected, that will give you a black and white picture. FR
Nov 30, 2008 | Bose Lifestyle 28 System
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony KP-51WS500 51" Rear Projection Television Logo
191 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
