Question about Maytag Washing Machines
I have a Maytag Neptune washer (model MAH5500BWW) that won't completely drain. It goes through the normal cycles but, but water still remains in the tub. Could the pump be out and how can you tell if it is?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Check the pump out flow of the drain hose, is it a good strong flow or does it seem weak and restricted. If the drain is slow the machine will stop before it is empty. Also if the drain hose is not vented, mounted too high in the air, or has a piece added on making it longer, it may degrade performance.
Posted on Mar 14, 2012
SOURCE:
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Problem with the Maytag Laundry Neptune Front-Load Washer- Maytag Neptune MAH4000AWW will not drain all the water out. When the machine cycle through the drain mode it drains really well (the flow out...
Yes and no. The neptunes have always had a bad problem with that. As long as the clothes aren't soaking wet after the spin cycle you should be fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500BWW keeps increasing time during the spin cycle. Also, is it normal for the washer to have water in it after the cycle has completed? The water is not visible but when you turn the tumbler...
Ok First lets start with the water in your washer. This can be a couple of things. It can be a clog in the drain line, or it could be the water pump,going bad. Sometimes an article of clothing like a sock or cloth gets in between the inner, and outer tub and it can even work it's way down to the drain, and into the pump. If this is the case. you will have to remove the drain hose and get the item out of the drain, or pump. if you do not see a clog, and if it is the pump, you will have to replace that.
Now with the extended time in the spin cycle, that is probably the timer itself. You can get all these repair parts through Maytag, you will have to take the cabinet apart, and it is a pain if you aren't use to it. But if you want to DIY you certainly can, just be careful, and make sure everything is unplugged first.
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
300 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
