Novitech PS-026/B2 I need the second step-up gear. (the last coaxial gear before the main shredder gear)
  • 2 more comments
  • drjohndi Nov 11, 2008
    Novitech shredder nylon gear broke. I hate to toss the whole machine for this part.
  • dianawithers Jan 21, 2009
    Cannot find a way to contact the company for any warranty, and the owner's manual I have is not the right one...
  • Anonymous Feb 01, 2009
    My shredder doesn't shred anymore, it ticks when you put paper in it. How annoying.
  • Kenneth Yoder Nov 10, 2011
    I need the same gear, ifd I send you the old one, can you return to me a new one?
3 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: REPLACEMENT INTERMEDIATE DRIVE GEAR FOR NOVITECH
Get me the model and serial number or just call Fellowes direct. They will sell you the part.
If not. Call me with the information and I can order it for you.
727-773-8973
Posted on Sep 07, 2009
SOURCE: NoviTech Paper Shredder will not feed paper forward.
Solution 1 worked for me. I unscrewed all 7 screws, pulled apart the cover carefully. Beware, there are wires attached. you can lay it side by side.
The activator is the white plastic thing. You need to make sure that it sticks out and as the paper goes from the top, through the cover, it hits the white activator.
At the end of the white activator, you see it has some plastic to push on the metal strip. This engages the forward motion. You'll here a click if you test the paper going through. This click is the sound of telling the motor to roll forward.
I think it got knocked out of place when I tried to insert a CD into it. Luckily, I didn't buy another shredder because of the Best Solution in this forum. So thanks for your help!
Posted on Aug 01, 2010
Are there wiring diagrams available for NoviTech PS-026/B2 shredders or just the PDF converter that you try to trick us into downloading?
we don't try to trick you into doing anything
The information given is generic because you have more information than you reveal and you are required to use the given information to produce ideas as to where to go to get the information to help
best advice for you now is to take it in for a service or repair and have it fixed properly
Mar 30, 2016 | Office Equipment & Supplies
Have a NOVITECH paper shredder- PS-026/B2. When slide switch is moved to ON it starts shredding and won't stop automatically until switch is returned to OFF
LOOK INTO WHERE THE PAPER IS FED... THERE IS A TINY SWITCH THAT THE PAPER TRIPS WHEN THE PAPER IS FED INTO THE SHREDDER. THIS SWITCH IS SHORTED OUT OR STUCK INTERNALLY FOR SOME UNKNOWN REASON.
Nov 20, 2014 | Shredder Office Equipment & Supplies
My Novitech Model PS-012A is stuck in auto mode and has the same problem as noted on this page for the Model PS-106/B2
For this internal technical problem you need to contact Novitech for their technical support. Call them at this number: 1-866-238-2490 for help.
May 20, 2011 | Office Equipment & Supplies
Have a NoviTech paper shredder, Model PS-026/B1 which will take paper, than stops! Need to reverse, than stops... What do I do?
Office Depot offers $30 to trade in an old shredder toward the purchase of a new one. They currently have an Ativa Micro-Cut on sale for $89.99, less trade-in makes it $59.99. If they accept the $10 coupon from their online survey, the final price is $49.99! Face it, shredder blades dull eventually, so look for them to go on sale and trade in/trade up!
Oct 25, 2010 | HSM 104.2 StripCut Shredder
Stops running
Sorry, No parts available.
Sep 27, 2009 | Fellowes DM15C Shredder
REPLACEMENT INTERMEDIATE DRIVE GEAR FOR NOVITECH PS-026/B2 SHREDDER
727-773-8973
Sep 05, 2009 | Fellowes DM15C Shredder
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Aug 27, 2008 | Fellowes DM15C Shredder
Removal of cover
there's a screw under the novitech sticker , bottom right hand side. btw anybody know where you can get parts/ or a parts manual for this?
Aug 24, 2008 | Office Equipment & Supplies
Novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Feb 12, 2008 | Fellowes DM15C Shredder
730 people viewed this question
k24674
jasbo
jasbo
