Question about kawasaki SVP500 Multi-disc DVD Player
Accidentally pushed PSCAN button...wont work now!
I accidentally pushed the PSCAN button on the remote while i was watching a movie. now, the dvds play, you can hear everything and it shows the progression through the dvd on the player, but the screen has black and white lines all over it and there isnt even a trace of a picture.
4 Suggested Answers
SOURCE: invalid disc
we also used my husbands converter (little black and decker he has for the "office" in his truck) and we had no problems the last time we used ours
Posted on Dec 29, 2007
  • 45 Answers
SOURCE: Portable DVD Player
make sure your player is set to the video output, and not set for internal use.
Posted on Mar 10, 2008
  • 28 Answers
SOURCE: DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Posted on Jul 30, 2008
SOURCE: player has sound of the
There is a small button on top when the screen closes it turns off the display. While the movie is playing press the small button with a small pointing object and see if the display shows something on the screen for a few second and then off (you can sometime see the movie playing but very dim). then there is a problem with the switch not switching the display back to normal. Hope this helps...
Posted on Aug 20, 2011
0 characters
1 Points
As I am watching a movie, I accidental press a button on my remote of the dvd then something came out of the screen. inorder to get back to where i am watching i keep on pressing buttons on my remote. The...
It sounds as if you have inadvertantly locked your dvd player. Try using the code 136900. If this passcode is accepted, then access the general setup menu (using your remote) and choose the Disc Unlock option.
I hope this helps. I completely relate to the frustration of this very problem.
Nov 03, 2010 | Philips DVP-3005 DVD Player
Black and white??
Press again that button
Jul 09, 2009 | TruTech DV288B3 DVD Player
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia DVD & Blu-Ray Players
Pscan mode
I had the same problem. Here's what I did to reset the progressive mishap...
  1. Turn on the player (without a disc inserted)
  2. Wait for the "no disc" message
  3. Press 1, 6, 7, 1, 9 slowly
  4. A menu comes up
  5. Select "Configuraton"
  6. Select region (0 = codefree)
Feb 26, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Pushed the pscan button by mistake
Should be as easy as pushing the pscan button again. You might need to unplug the dvd player for a while till it goes back to factory. The P is for progressive scan and your tv must not support P. Once you get it turned off it will work again. There also might be a button on the remote to turn it off.
Feb 06, 2008 | Starlite NP625 DVD Player
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Memorex dvd player pscan split screen
on the back of the dvd there is a black interruptor, it should be set as PSCAN OFF. thats all folks
Nov 02, 2007 | Memorex MVD2042 DVD Player
DVD has no color
Check your remote for a button that says, Progressive Scan, or PSCAN. Push it and then play your movie. Should work. Worked for ours. Good luck.
Sep 15, 2007 | DVD & Blu-Ray Players
kawasaki SVP500 Multi-disc DVD Player Logo
Top kawasaki DVD & Blu-Ray Players Experts
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
