Question about Desa International Blower Glow Warm Wall Heater
My glo-warm propane heater keeps shutting off automatically-pilot and all.
My glo-warm propane heater keeps shutting off automatically---pilot and all. Plenty of propane, nothing else is different from last year and I've run it long enough that anything should be out of the line by now.
  • 1 more comment
  • jam8407 Nov 18, 2008
    Mine does fine on High and Medium, it's when I try to leave it on Low that it shuts down.
  • ndhtrhlp Jan 13, 2009
    I have a Glo-Warm 30K BTU wall mounted propane unit. Installed 3 years ago. Designed to cover approx 1000 sq feet, covers first floor of home which is 994 sq ft overall, approx 650 sq ft if I close of unused rooms to just heat living space in use.
    Unit connected to less than 8 feet of iron gas pipe, last 1 foot of which passes through wall to exterior of house. Iron pipe then connects to approx 30" corrugated line, then regulator / fitting which connects to 100LB propane tank. I have a stryofoam cover over the tank connection / regulator that I fashioned out of a cover normally used for an outside water spigot in winter, the sides are cut out. (Reason: used to have rain / snow freeze onto regulator).
    Iron line installed with a "trap" beneath the heater for debris / water, this is clear. Iron line "slopes" downhill slightly from heater as line passes through wall to exterior of house, then meets corrugated line which curves gently upwards to meet the tank (no kinks). Corrugated line does no appear to have water or debris in it.
    Operational details are as follows:
    -- unit worked flawlessly when first installed 3 winters ago
    -- unit has manual pilot / piezo igniter and variable gas control
    -- last winter, and now progressively moreso this winter, unit does not work when outside temp drops below approx 20 - 25 degrees F
    -- if outside temp is above 20 - 25 degrees F it works absolutely flawlessly, strong clean blue flame, output as if brand new
    -- unit usually has pilot, but pilot "shrinks" when you turn up the unit to "ON" , possibly due to the "draw" of feeding the main burner
    -- when very cold, pilot will ignite for a few seconds, then burn out, must wait a while to try to reignite pilot, unit rarely works to fire burner afterwards (perhaps pilot runs on propane in line, then poor volume or pressure causes it to exhaust the propane in the line before it "backfills"?)
    -- if I am using unit as the outside temp drops, flame height in the unit decreases with occasional "orange": (oxygen?) "spikes"
    Should I:
    -- replace the thermocouple
    OR
    -- replace the regulator
    OR
    -- perform other troubleshooting?
    Thanks very kindly for any assistance or advice ... J V
  • LDRunion Jan 17, 2009
    I have the same proplem with mine, bought new about 3 years ago and with 3/4 ful 100 lb tank of propane it works good for about an hour then hear a click and shuts down. I can let it set for about 1/2 hr and relite it but runs for a little bit and shuts off again. I bought 2 trermocouples but wouldn't fit, made by honeywell company. most of the time if it's above 20 degrees it also works well but under 20 when I noticed that it shuts down. Took it apart and made sure it was clean "no problems there"
    Larry (Westmoreland, TN) any sugestions my email is:
    Lonelytravler56@yahoo.com
My heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
    Problem Solver:
  • 17 Answers
Clean the pilot and if that does not help replace the thermocouple. Also make sure you have correct ventilation to the room as that can also cause this type of heater to shut down.
Posted on Nov 18, 2008
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
CAN YOU TELL ME HOW TO REPLACE THE THERMOCOUPLE IN A DYNA-GLO PROPANE HEATER?
These thermocuoples are some of the finest ever made. The pilot not staying lit means you automatically want to try and change the thermocouple which is a costly one. And that will not fix the problem. The problem with these ODS pilots is they get dusty in summer. The safety device needs to be flushed to clear out the dust. I use rustbuster to gently flush out the pilot. I let it dry out and then light the pilot.
I had one I got all ready for winter today. Thanks for reminding me. I took some photos:
How it works and more HERE
Oct 25, 2011 | Dyna-Glo D-E39 (LP) Wall Mounted Panel...
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a 30k btu glo warm heater how do u switch from propane to gas
change the pilot n burner orffices. they r larger than propane gas orffices. good luck
Nov 23, 2009 | Heating & Cooling
How do i adjust the flame on ,my glo-warm propane heater?
if there is any adjustment it will be on the gas valve itself under the front of the unit....should have a little door that pulls down....you should see a knob that says "Higher....Lower" something like that....if the knob only says "ON , Off and Pilot" there is no adjustment
Oct 19, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Oct 19, 2008 | Desa International Blower Glow Warm Wall...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Desa International Blower Glow Warm Wall Heater Logo
6,786 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
