Question about Philips GOGEAR SA6045 MP3 Player
Tmpt test 2
When I turn it on it flashes an "intializing" screen and then goes off. When I run the production test it says that "tmpt test 2" fails
  • xaviermonoso Mar 01, 2009
    hola, segui al pie de la letra tus instrucciones(pues tengo el mismo problema) pero no se soluciono, antes el device manager no encontraba el gogear en mi ordenador, ahora si, y aparentemente lo "repara", inclusi dice: esta reparado, puedes desconectarlo del ordenador... pero lo prendo y dice lo mismo "initializing"... me puedes ayudar?, no me diggas que lo tengo que cambiar, pues ya no tiene garantia :(
  • 8,596 Answers
A key system file has been deleted. Go to Philips website and attempt the firmware upgrade, but it probably will not work. You may have to replace this player.
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
My g60 -235dx laptop on startup error message say communication problem with I/O deveice, HD, flash drave , CD-ROM
G60-235dx. (2011 model, is my guess)
ok tell the full story please.
PC boots sequentially.
progress in that matters. so it seem windows unstated runs?
XP?
so you power on and what happens ?,
errors before windows logs in or after.?
my guess #1 is the main laptop battery is bad, remove it.
this pC runs on AC power pack endlessly, (AC power good)
dim screens. can be bad CCFL lamps or low power in the PC.
so again take out the battery
what flash drive, remove that, test the pC with no usb devices at all plugged in.
just an A.C power pack and no main big battery.
this PC has old CCFL lamp tubes that all go dim, fast.
turn yellow then dim the flicker and then DIE for ever.
all do. some in 2 years time never turned off. they do.
it the screen goes black use a flashlight if data is good on the screen the back lamp is croaking. (***** of CCFL tubes)
there are many cause of black screens, I can list 30. (will not)
but dim screens are only
1; main battery bad and shorted.
2: AC power pack near dead. (weak happens)
3: shorts in the main board, modules.overloading power buses.
4: CCFL dim as every one this old does, all do.
see flash light test.
http://www.pcdied.com/monitors.html#flashlighttest
Oct 18, 2017 | HP G60-235DX Notebook
This printer runs the self test for more than 2 minutes. When it settles from self test, I try to print and it does not print when I command print. The printing queue is empty. I have tried to uninstall...
I under stood, its not self test its keep on intializing more than two minutes. Replace the DC controller, check system recognising the divice or not,if not you need to replace the formatter also at time..good luck..
Sep 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Hewlett-packard hp biscotti. the LCD screen keeps flashing a blue and white screen and won't even let me log into windows. I've had this for less that a week and problems were noticed from day one (the...
HP Biscuit. i take mine with butter, LOL
G72259 (missing dash)
NO OS STATED no op system , W7?
i cant ever tell anyone there skill sets, who can?
if you had posted a photo of the mess on that screen we SURE
can answer, accurately,
explaining any screen in words, is mostly a waste
except like , (black screen with these words frozen
the real name is (and old)
G72-259WM
Intel Pentium dual-core
does it run battery out ., and AC line pack plugged in correctly?
i guess its 7 years old?
step 2 does BIOS work
power on, hot keys ESC, F9 F11.
does the BIOS message
"hit ESC key to enter HP setup" does this show up
IT MUST AND IS STEP 2,
getting to windows is next.
step 3 if windows is corruptted
the F11 key reloads or run F11 restore, hit fix starter fills.
step 3, BIOS , go to the service page
run ram test.
then run HDD test.
do they pass
if HDD fails, its bad, a bad drive.
Jul 04, 2017 | HEWLETT-PACKARD HP G72259WM Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
HP 15c Passes self test but screen flashes - wont turn off
You can get rid of the flashing (usually due to memory overflow) by pressing [<-- left arrow] [ON] or [g] [CF] 9.
If you want to reset permanent memory
1.Press and hold [ON] then press [-]
2. release the [ON] key, then the [-] key.
Screen displays Pr Error.
Press any key to clear display.
Hope it helps.
Sep 25, 2009 | HP 12c Calculator
8008273a error
Go to Settings > System Settings > Restore Default Settings
reset your settings, if this does not work and you are running custom firmware follow these steps:
1.- hold the power of switch till screen goes blank
2.- turn psp back on while holding the right bumper
3.- once on the recovery screen go to Advanced > Format Flash 1 and Reset Settings ( you will get a blu screen but dont worry about it and just press O.)
If all fails then just try re flashing your PSP with your current or an update custom firmware.
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
Philips GOGEAR SA6045 MP3 Player Logo
280 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
