Need Instructions to use Fireplace Gas Logs
Hi - The house we recently bought has a vent free gas log fireplace insert. The manufacturer is SFC and the model is UVFR-43 and 003903.
We have a floor mounted gas control valve. The fireplace has an ignite button and a control knob with "off, ignite, low, high" markings.
We were able to light the logs and they're burning.
Question: When we turn the logs off, do we just turn the control knob to off? OR, do we also use the manual gas control and turn that all off as well?
  • Mary Sutton Nov 23, 2008
    Ours does not have a wall switch. That's an optional item and ours doesn't have one.
    Thanks anyway.
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
Wind blows out the gas logs
I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Jan 11, 2016 | Majestic Fireplaces Majestic VWF24NMD 24"...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at americanhearthandhome1@yahoo.com
Thanks ... Rich
Feb 16, 2011 | Heating & Cooling
We have a Marco fireplace and the damper does not shut. I push the leaver inwards but nothing catches to keep it closed. We purchased this house and the fireplace was replaced with Gas Logs but still...
when the gas logs were installed the vent damper should have disabled. it sounds like this was done.it is unsafe to close the damper with gas piped into the fire place. sometimes a "u" block will be placed over the damper blade. if the gas has been removed and not piped into the firebox anymore it would be safe to remove this
Jan 27, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Can one use unvented gas logs in a superior CF3860 fireplace?I
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
Dec 03, 2010 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
I recently bought a house w/ a Marco gas fireplace and there is no owners manual. I have never used a gas fireplace, so I have no experience with this. I would really like to get an owners manual, but...
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
Nov 08, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
1,016 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
