Question about Kenmore 23822 Top Load Washer
Kenmore 110 Washing Machine -
On the spin cycle the machine makes a terrible noise and shakes the machine. It usually does shake on the spin cycle but this is a loud
bearing noise. If I open the lid and balance the basket - it helps. Someone told me this machine has no belts and says it sounds like a clutch going out. Is this machine worth placing a service call on it? I bought in 1992.
  • 88 Answers
These machines are good washers. If you rearrange the load and that does not help, the washer not be level.This washer if it is the one I think it is, it does have a belt very seldom do the clutches go out unless you you maybe do50 loads a day. my guess is that it is not level and you will need a short level and place it on the front edge of the washer and see side to side then on the right or left side front to back . Most of these are equipped with self levelers. Put your foot in front of the washer at the base pull forward on back to lift the rear feet off the floor about 2 inches and set it carefully back down then check both ways again until it shows level, you may have to repeat this once or twice. If it still shows not level you my have to turn the front feet in or out until level. Remember use a combination tilting to the front and adjusting the front ones.
Posted on Nov 18, 2008
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Washing machine shakes excessivley and the washing cycles are stopping mid use.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 06, 2011 | Kenmore Elite 45986 Front Load Washer
Front loading machine shakes violently during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Jul 01, 2009 | Washing Machines
Kenmore washer stock no. 22642 shakes terribly during spin cycle
There is a suspension plate under the tub.
It also has 3 pads on it to support the tub.
There are springs attached to support the angle of the tub.
Check all these parts and repair or replace as necessary.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Feb 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 23822 Top Load Washer Logo
120 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
