Question about LG WM-2277HW Front Load Washer
LG doesn't spin!
My LG washer doesn't spin. It turns manually but no by itself. I received a LE error!
  • 1 more comment
  • gbolanos12 Nov 04, 2008
    Actually the washer was working fine untill a week ago that all the sudden stopped. Washer is 3 and 1/2 years old.
    Actually the washer was working fine, and all the sudden stopped and I received the LE error message. The washer is 3 and 1/2 year old.
  • gbolanos12 Nov 05, 2008
    Thank you everyone for all your suggestions and comments. I really appreciated!
Just has this exact washer repared by PC Richaard technitian today(luckally I had warranty). I had exactly the same problem - does not spin with LE error code.
Problem is in the broken sensor in the motor. It took 5 min to repare. He removed a back panel from the washer, unscruded sentral bolt and 6 bolts fixing a motor to the washer. The sensor is inside and it connected by 6(or 8) pin cable.
Now works like new.
Posted on Nov 05, 2008
    Scholar:
  • 62 Answers
Have you had this problem from the beginning? I would also take a good look at the flooring where the machine is located. If the flooring is weak or not as solid as concrete you may have a hard time keeping it from shaking. One of the other common things that I see is most people don't put a full load in the machine. Since this is a front loader, it will have a better chance of going of balance with a smaller load than a larger load. If the floor shakes (on a wood floor or similar material) then the answer would be to strengthen the flooring, or take it to a place in your house where you have a solid concrete floor and try to spin it out. If you are already on concrete then the previous suggestion or possibly an issue a tech should look at.
Posted on Nov 04, 2008
  • Steven Haney Nov 05, 2008
    My apologies, I must have confused this with another problem. LE error code usually is an over loaded load , maybe oversudsing, but my LG washer usually needs the filter cleaned out . If you have an access door on the bottom left corner of the front of the machine , inside that access door is the clean out filter. I will double check the model you have to see if it has something on the error code . Do you have the manual? If so does it tell you what that code means?
    Just checked the manual and it shows an overload in the motor mine did this and I let it cool down, unplugged the unit, then restarted. My son had washed a full-to-the-gills load of all socks. If you havent had a large load or something and restting it doesnt work then you might need to call a tech.
Are the 4 shipping bolts taken out of the back of the machine?
Posted on Nov 03, 2008
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
My lg washer, wm2277hw, has the LE error code, so how do I manually make it spin to extract the water.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG WM-2277HW Front Load Washer
My washer has an LE error code. It makes an attempt to spin after beginning a cycle, once the drum doesn't spin the error code is flashed.
'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor when there is vibration/movement from the drum turning, requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 06, 2011 | LG WM1814CW Front Load Washer
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG washer
23d2381.jpg This info is right out of the LG Service Manual.. Hope this helps..
Aug 16, 2008 | LG WM-2277HW Front Load Washer
LE error code on LG washing machine Model WT-R801, goes through all cycles, then when supposed to spin it comes up with this error, even on a small load.
Looking at several LG Washer service manuals, the error code LE ( Lock Error) could be any one of several things: a 3 pin connector in the wire harness going to the motor, It could also be the harness itself between the Motor and Circuit Board Controller ( PWB) assembly has been damaged or cut..or the hall sensor used to detect drum speed while it rotates may be defective or the main control board ( PWB) "printed wire board " is defective. Lots to pick from but these are the likely candidates... hope this helps
Aug 08, 2008 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
182 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
