Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How do you replace a bad thermostat in an icemaker?
You replied to my question about my icemaker not dumping the ice it has made. How do I replace the thermostat?
  • 59 Answers
First you have to remove the icemaker. The is one 1/4in screw holing the in on the bottom back right corner. Once that is removed you can remove the plastic shield that it was screwed into by pulling up and back on it. After that the icemaker can be pulled straight out towards you. (it might take a little force and wiggling of the ice maker to do so) Unplug the icemaker by inserting a small flat screw driver under the tab at the harness.
On the right of the icemaker is a white square cap. Remove it to expose a big gear. Check the pins in the middle to make sure they aren't broken.
If the pins check ok then the problem is either the motor or thermostat. To replace the motor the whole part in the picture above (the Module) needs replacing (Part#W10122536) To replace it remove the three screws in the top two and bottom right corners, pull off the module and replace it with the new one.
To replace the thermostat (part#627985) remove the module and set it aside. Under where the module sat you will find two screws. Remove them and pull out on the black plastic casing. (Be careful because the the ice arm and stripper will fall off when you do this. In the bottom middle of the opposite side is the thermostat. Pry it out and place the new one in. You'll need some stuff called alumilastic. (Part#4317852) Put a dap on the new thermostat and put it all back together.
After It all back together and in its place it may take a couple of hours for it to make the first batch of ice. Good Luck and let me know if you need any clarification.
Posted on Nov 03, 2008
New icemaker will work manually, water and cycle but will not fill after it dumps ice.
Try vacuuming the condenser coils of lint. The icemaker resets and harvests by a thermostat. If the freezer isn't cold enough it may not reset for a harvest. The icemaker could also be just bad.
Mar 12, 2015 | Refrigerators
Ice maker not dumping ice
It could be the harvest thermostat or the mold heater is bad on the icemaker. It is usually better to just replace the icemaker. Installing a harvest thermostat is a but tricky and the mold tray is 3/4 of the icemaker anyway..
Apr 08, 2014 | Refrigerators
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice cubes form a mass that do not dispense
Sep 11, 2009 | Kenmore Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Ice maker quit dumping ice to the tray
You have a bad icemaker thermostat ( replace the whole icemaker ) or the temperature is not at least 5 degrees cold . You might check your coils to make sure they are clean (usually at the bottom from the front of the fridge ) only vacum or brush what you can get to as this will also keep the icemaker from harvesting .
Jul 10, 2009 | Refrigerators
Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Nov 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
891 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
