Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
DETERGENT CUP DOOR DOES NOT OPEN? - Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
  • HONEYBOY Nov 03, 2008
    GINKO, YOUR ANSWER WAS NOT CLEAR. WHAT DOOR ARE YOU REFERRING.ALLOW ME TO GIVE YOU MORE INFRO. MODEL # 665 156 0592. tHE DETERGENT CUP DOES NOT RELEASE DETERGENG DURING WASHING CYCLE BECAUSE WHEN THE MACHINE COMPLETES WASHING THE DISHES THERE IS SOAP REMAINING. I REPLACED THE SOLENOID TO NO AVAIL. THIS DISHWASHER HAS BEEN WORKING FINE FOR MANY YEARS . LET US TRY AGAIN. THANK YOU. PS. IT IS A KENMORE!
  • HONEYBOY Nov 05, 2008
    on my kenmore dishwasher the detergent cup lid does not open during the washing cycle. after the cycle is complete,there is soap still in the cup and the dishes are not completely clean.i did purchase a new solenoid but the problem still exist.the model#665 156 0592.the dishwasher seems to otherwise works very good.thanks,Len.
  • 76 Answers
Http://www.applianceaid.com/soap-door.html#open
try running distilled vinegar on heavy cycle first w/ no dishes in the unit. if you still have a problem go to this link it sounds like it may be your timer. hope this helps. you should run the vinegar monthly to help prolong the life of your dishwasher. :)
Posted on Nov 05, 2008
  • 728 Answers
It may be from either a short in the circuit board that controls the door opening, a power cord that leads to the door is broken and not allowing power to the door, or it could be something jamming it and not letting it move. Try and see if you can push the door open with something small. If it does not move, then it is probably jammed and you need to try and see what is jamming it. If you can push it open, then you will need to get a profession to look at it and see if they can fix it.
    Sergeant:
    Champion:
  • 347 Answers
Hello HONEYBOY,
The cup door is very likely stucked with something sinside small object,  just dust, or simply friction.
Try to pull it harder, if you cant open it, use a coin, a screwdrievr or soemthing thin
to make a lever and open the door. (make sure the object is not fragile, because if it breakes, it will add more pressure to the door and it will be harder to pull it out)
Good luck and anything else you  need let me know,
Dahaka
Posted on Nov 03, 2008
    President:
  • 2,712 Answers
Could be that there may be a lump of old detergent that may have dried and is blocking it. Try pulling it out gently with a bit more force. If you get a slight space available, try running a wire through the gap and dislodge the caked up detergent.
    Genius:
  • 1,550 Answers
You need to provide more information .
Its just a single line and it is not clear enough .
  • Kenmore Master
  • 19,396 Answers
There is a tab on the top side of the drawer, try inserting a not pointed knife or a screwdriver and lower the tab.
Soap remains in dispenser after completed cycle and dishes are not clean
Hello laura.... there are three possible causes of the dispenser not opening:
1.Timer
On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. 2. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. 3. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly That said, one way around this is to simply add the soap or the soap tab into the dishwasher proper, not into the cup. Joe Thanks for choosing Fixya!
Mar 13, 2011 | Maytag Dishwasher
Dispenser does not work
Hello there:
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
Jan 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser will not open automatically in a wash cycle
Hello there:
Please follow thew following solutions i have provided below
The detergent cup doesn't open When the detergent cup or dispenser will not operate properly or doesn't open, check these:
Sep 26, 2010 | Frigidaire Dishwashers
Where do you put the dish wash detergent for my dish washer!
Hi, for most dishwashers the detergent cup is behind a little door in the door of the dishwasher.. snap open the door and place the detergent in the cup while the door is open and down, then close the little door and then close the dishwasher door...
then you are ready to roll...
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | Dishwashers
When i choose normal wash and the cycle has been complete I open up the dishwasher and at that time the detergent pocket opens up and drips out the detergent. My glasses are all chalky and unclean
When the detergent cup doesn't open, check these:
Timer
Jul 16, 2009 | Dishwashers
Not using salt
Timer
Jul 06, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Detergent cup door partially opens
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
y
Mar 21, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Detergent Door not Opening
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, you should replace the wax motor that operate the cup door. Good luck
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Jun 20, 2006 | Maytag PDB3600A Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
27 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
