Question about Sony VAIO GRT170 Notebook
Sony VAIO GRT170 laptop fans wont run.
ive had this laptop for about 5 years now. both fans will not work now and the laptop with shut down after about 3 minutes. i know the fans are not the problem, because they still run off of a 9v battery. i was wondering if there is anything i can do without replacing the motherboard.
  • Sony Master
  • 19,396 Answers
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Posted on May 21, 2009
My Sony VGN-CR590 shuts down after 5-10 minutes. How can this be fixed? I'm not sure the fans are running.
A way to check to see if the machine is overheating is when you turn on the computer, there should be an option to hit F10 or F2 for the bios. In there, there should be a few temperature readings. Let the machine idle and in the bios if the tempature rises in there there could be an issue with the cooling for the CPU.
Jul 11, 2012 | Sony VAIO VGN-CR590E PC Notebook
My Sony Vaio laptop shuts down suddenly?
It might be overheating take a can of compressed air and thourgly clean the fan port and inside the port
Oct 28, 2011 | Computers & Internet
My laptop Sony Vaio CS 320J is shutting down with out any notice(not proper shut down but poweroff while running) and not booting again for @ least 2 mins. recently this issue started and this is...
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Apr 15, 2011 | Sony VAIO VGN-CS320J Notebook
Looking for keyboard of sony vaio
Try contacting "Sony Accessories and Parts Center" for the Keyboard.
You can contact them at the below Phone Numbers.
Priority Service: 1-239-768-7691Toll Free Service: 1-800-488-SONY (7669)
Phone Hours:
Monday to Friday - 8:00 am to 12 am (Midnight) ET
Saturday and Sunday - 9:00 am to 8:00 pm ET
Aug 14, 2010 | Sony VAIO GRT170 Notebook
My sony vaio VGN-B1XP, running windows XP, keeps shutting down. It is now 5 years old?
hi
thank you for using Fixya
if your windows shutting down in startup then you have problem with windows only
if your windows runing till your desktop then it's shutting down it meance u have virus in your pc
May 14, 2010 | Sony Computers & Internet
Vgn-cs26m will not start,boot into windws and shuts down
kevin,
Is this the pink sony vaio? Looks familiar . . .
The problem with this model of sony vaio is the fan that's why it keeps on shutting down after a few minutes. If you notice there is no activity on the internal fan. The internal fan and heat sink is on the same module.I have already replaced the fan on one of this models and its now working just fine.
just look for a spare fan on ebay . . .
hope this helps . . .
Apr 05, 2010 | Sony VAIO VGN-CS260J/P Laptop
My Sony Vaio laptop turns off constantly. It
When it is running I need to know if the air coming out of the vent slats is hot or just warm. It sounds like the laptop is overheating and shutting down so it doesn;t burn itself up. Get a can of compressed air they sell at office supplt companies and use short bursts of air in the vent slots and fan housing. If there is an access panel on the bottom that allows access to the processor and heatsink, blow that area out too. Then check the Sony support site and see if they have a BIOS update for that model computer. Some manufacturers are writing new BIOS instructions for their laptops for the fans to run longer and faster to take care of heat issues.
Sep 06, 2009 | Sony VAIO PCG-K35 Notebook
Hotkey utility not working Sony VAIO GRT150 PC Notebook
You can get the Hotkey utility driver from the link below
esupport.sony.com
It will give you the driver's list and you can get the hotkey driver under the
Notebook Control and Utilities - 2 file(s)
Feb 27, 2009 | Sony VAIO GRT170 Notebook
Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Feb 18, 2009 | Sony VAIO GRT170 Notebook
Loud Fan on The Sony Vaio PCG-K33
Get a NotePal by Cooler Master. Go ahead. Google it. Froogle it. Compare prices. and buy. My K33 5 years, running great, noisy as hell
Nov 28, 2008 | Sony VAIO PCG-K35 Notebook
Sony VAIO GRT170 Notebook Logo
405 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
