Question about Samsung RS2578BB Side by Side Refrigerator
Samsung rs2578ww help. My freezer is fine but my controls are blinking 61 on refrigerator side. I have unplugged and plugged back in . Now its not blinking but not getting cold. repair guy can't be here untill tues?????????
  • James Kemfort
    James Kemfort Aug 06, 2008
    My problem is opposite. The fresh food side works fine but the freezer side started blinking. I tried unplugging and re-plugging to reset. Now the freezer side temp has gone to 61. The fan works when I push the light switch in.
    President:
  • 878 Answers
Littlern, Im thnking the 61 was your ambient temp on the refer side. The codes show up differnt than that. This is a very complicated machine. Sounds like a temp sensor has gone bad, the main board or the compressor overload itself. You can put it into a self diag mode by pressing power freeze and power cool together for 8 seconds. This is going to test all the sensors, fans, defrost cycles. The error that comes up will show as a - or | running clockwise on a digital 8 figure and then has to be decoded on a chart. For exampe: If the - is present on the bottom side of the 8 in the display, this means a a number 4 error which means a rerigerator fan error. It's gets pretty confusing, it's good you called the service tech. Make sure to get an extended warranty on this model..Catriver..post back.
Posted on Oct 02, 2006
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Freezer is very cold fridge is 61 degrees
You could have a plugged drain tube under the evaporator coils(behind back freezer panel) which is causing the ice in the bottom of the freezer(when it defrosts). If it also is pluggged with ice to the air return from the refgigerator to the freezer side it will cause the problem you are having. Or you have two problems, plugged drain tube and evaporator fan not running or plugged drain tube and damper control iced up......
If you have a back-up unit, leave it unplugged for a day with the doors open to thaw out, may not help, good luck though, hope this helps
Jul 29, 2012 | Frigidaire DGHS2644KF (260 cu ft) Side by...
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a side by side refrigerator/freezer by samsung and on the digital display the fridge temp (currently set to 2 degrees) is flashing.what does this mean many thanks
If the blinking continues, you may need to “reset” the Refrigerator. Try unplugging the appliance, wait for
around 10 minutes and then plug the power cord back in.
Jul 11, 2008 | Samsung Refrigerators
Samsung RS2545SH Refrigerator
Diagnostic mode will say what any electronic issues are. Check to see if there is, if any, frost build up on the rear panel or ports. If the unit had made any noise in the refrigerator. This unit may have a switching valve for the twin cool, so it could be an issue there.
Dec 02, 2017 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
595 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
