Question about Kenmore 24 in. 15932 Built-in Dishwasher
The sensig is on, and can't get back to normal cyle to wash dishes
I always was ndishes in normal cycle but my brother some how touched the the sensing button and it count down from 9 then it turn off. i can't get it to wash my dishes on any cyle cause it's almost like it locked on sensing? what can I do?
  • dgiuffrida40 Nov 04, 2008
    when do i push the cancel button? do i start the sensing cylce and wait til count down 9-0. or do it whie its doing nothing?
    Sergeant:
    Champion:
  • 324 Answers
Try to just push the cancil button 2 times that should cancil anything he did if this does not work then you have a problem with the dishwasher
Posted on Nov 04, 2008
  • push start then when there is a display then push cancil 2 times.
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
The dish washer fills and wash cycle begins, however stuck at wash does not progress to rinse cyle
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 03, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishes always come out cloudy ... white cloudy stain on inside of door, etc. We use electrosol power ball cubes. We set wash cycle to normal wash.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 18, 2009 | Maytag MDB7100AWB Dishwasher
Blue sticky spots in my dishwasher
some of the soaps out there are tempurture sensitive, several different ingrediants waiting on different temps during differnet times of the cycle,
I have seen this before or at least something similar,
does the soap your using now have the jet dry as part of it
if yes id go back to jet dry, your rinse cycle is not hot enough to fully disolve the jet dry in the soap, it gels and coaleses every where.
its designed to do that, so it will not just be washed down the drain on the wash cyle with the rest of the soap.....
Oct 11, 2009 | Dishwashers
Turn washer to normal or gentle cycle water will
add a pail of water if it starts adjust level control
Aug 11, 2009 | Washing Machines
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Stopped working during a wash
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher
If your water level is below the heating element that is normal after a wash. Some unit the water will not always drain (relates normally to low water pressure or hose length or height)
If your water level is below the heating element and your dishes ALWAYS clean then its fine, the water drains out before a new wash so you are not using the same water
if water is above heating element, run garbage disposal to clear lines if one is installed, if not you could have a clogged line/hose/sump/filter
May 02, 2008 | Dishwashers
Door
if it is after the wash cycle, it is normal to take a few minutes before the door will open. if it is after a dry cyle, there is a problem with the door mechanics
Nov 15, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Maytag PAV1000AWW washing Machine
Your machine has a two speed motor. If the motor hums as it tries to spin in the normal cycle, it could be the motor. If there is no noise, it could be a timer related issue.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
114 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
