Question about Indesit W 123 Front Load Washer
Electronics, location of eprom on pcb
I Need to find the location and orientation of the eprom micro chip on the pcb module for an indesit washer dryer , model widl 126s uk. I bought a replacement module but the eprom comes seperate and needs soldering in.
  • glyn marfleet Nov 04, 2008
    The serial number of the machine is 511103241. The code on the pcb is 215009366.03
    serail number on pcb is 809040357
    Top Expert:
  • Indesit Master
  • 78,289 Answers
Do you have the board out yest?
Posted on Nov 04, 2008
  • 102 Answers
I also Agree that you can damage your board if you are not careful. Let a pro do it.
  • 1,879 Answers
Look closer at the replacement module, a marker for PIN 1 should be there. Post a photo of the PCB and the EPROM so that we can all see what you have.
    Genius:
  • 1,550 Answers
This job can be done only by professionals .
Dont risk yourself by attempting to solder eprom .
Posted on Nov 03, 2008
  • 728 Answers
You may need to get that professionally done because doing it yourself may cause other things in your path to the micro chip to malfunction, causing your washer dryer to be useless.
  • Indesit Master
  • 19,396 Answers
It will be useful if you can give me the board number, so that I can look for a diagram for the board. It is printed on the board.
My machine starts to fill and then stops. It flashes 7 times. What is this error?
What is the Brand and model of your washer ?
Is it Indent ?
Many basic UK Indesit washing machines fitted with a rotary dial indicate error codes by clicking the dial continuously round and flashing the door lock light a set number of times.
If the door light (LED) flashes 7 times it means, "Heater relay stuck - check connections on heater and module (PCB)".
In my experience, this fault code usually required a replacement PCB and EEProm. A connection fault on the heater usually results in the entire washing machine going dead. Nothing will work, but the LEDs light up. This symptom can also be caused by an open circuit motor or other faults.
It's always possible for a connection fault to cause error codes but the heater relay is embedded in the PCB and if it develops a fault the whole board needs replacing. I don't recommend replacing the PCB as a DIY repair. It is an expensive part and it will not be guaranteed unless fitted by an engineer. New PCBs do not come with the micro-chip EEPROM which would also need fitting. Replacing the PCB and EEPROM yourself is risky. If the fault is not cured you cannot send the parts back.
If you have an engineer to replace the PCB and EEPROM I would imagine the cost is likely to easily be over £100. If your washing machine has a 5 year parts guarantee Indesit would supply the PCB free of charge but only if their own engineer fits it at a cost of about £90.
If you are really keen to fix this yourself and want to try another PCB there is a company that might be able to help and are happy to deal with the public called Quality Electronic Repairs (see link below)
Mar 07, 2016 | Washing Machines
Machine stops working and shows F09 what does this mean
Really need the make and model as different manufacturers use the same code to mean different things. Hotpoint/Indesit/Creda F09 on almost all appliances means "Eprom Fault" this is a problem with the main control chip and you will need an engineer to reprogram the main module or swap it out. If it's Bosch, then the good news is F09 means "Heater Fault" which almost certainly means a cheap £20 replacement heating element needs fitting
Sep 19, 2015 | Washing Machines
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Need to locate eeprom.
Hi there.
EEPROM stands for Electrically Erasable Programmable Read-Only Memory. An EEPROM is like an EPROM chip since it can be written in or programmed more than once. Unlike the EPROM chip, however, an EEPROM chip need not be taken out of the computer or electronic device of which it is part when a new program or data needs to be written on it.
The BIOS is the EEPROM chip, so you have to note what BIOS version it is AMI, Pheonix for example, this chip is located on the laptop motherboard and will be clearly marked.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq 6710b Notebook
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Model widl 126s wash/drier. module blown up new module cost minus eprom what is an eprom anyway! is £110 how can they charge nearly half the price of a new machine? price check at comet for later...
i agree - an absolutely crazy situation. however be wary about replacing the module. they can blow up because of a fault on another part like the motor short to earth
Aug 28, 2008 | Indesit Washing Machines
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Water supply was too low,machine stopped mid cycle.pessed start again machine restarted but then stopped again about 10 mins later. call service centre is now displayed on the screen when machine is...
I suggest you check the fuse on electronic module which is located to the right side of the drum. Getting to it no easy task as you must remove the rear panel and top cover and jam an object thick enough for your arm to passbetween the drums and the machine body. Please ensure you earth yourself before touching this pcb as the static in your body may blow the intergrated circuits and eproms.
I hope this solves your problem.
Oct 16, 2007 | Dyson Flowcheck CRO1 Front Load Washer
Flashing F12 on display
F12 is either the motor, or eprom chip on pcb. Most likely to be motor
Jul 09, 2007 | Neff W5340X0 Washer
Indesit W 123 Front Load Washer Logo
118 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
